I want to assign two VLANS , vlan 100 and vlan 200. intereface ethernet 2 will have both vlans and it is for hotspot. interface ethernet 3 would have vlan 100 and interface ethernet 4 would have vlan 200. However after configuring the vlans , putting vlans on bridge , assigning dhcp servers on the bridges , the interfaces would not get the ip address from the dhcp server. What did i do wrong?
Are the DHCP servers showing as valid status? Maybe upload your config - output from /export compact.
If you mean that your ether interfaces do not get an address, that’s obvious. If that is what you want you should setup DHCP client.
i added the interfaces to the bridges together with the vlan. Now the problem is the vlan is not working as i can ping from vlan 100 to vlan 200.
[admin@MikroTik] > /export compact
jan/02/1970 00:09:00 by RouterOS 6.1
software id = A3ZI-34IN
add l2mtu=1594 name=bridge1
add l2mtu=1594 name=bridge2
/interface vlan
add interface=ether2 l2mtu=1594 name="vlan 200i" vlan-id=200
add interface=ether3 l2mtu=1594 name=vlan100 vlan-id=100
add interface=ether4 l2mtu=1594 name=vlan200 vlan-id=200
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
add name=pool1 ranges=192.168.100.2-192.168.100.254
add name=pool2 ranges=192.168.200.2-192.168.200.254
add address-pool=pool1 disabled=no interface=bridge1 name=dhcp1
add address-pool=pool2 disabled=no interface=bridge2 name=dhcp2
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin password=""
paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no
permissions=owner signup-allowed=no time-zone=-00:00
add backup-allowed=yes disabled=no login=MikroTik password=qwerty
/tool user-manager profile
add name=hotspot name-for-users="" override-shared-users=off owner=MikroTik
price=0 starts-at=logon validity=0s
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name="" ip-pool="" name="1hr Limit"
transfer-limit=0B upload-limit=0B uptime-limit=1h
add bridge=bridge1 interface=vlan100
add bridge=bridge2 interface=vlan200
add bridge=bridge2 interface=ether4
add bridge=bridge2 interface="vlan 200i"
add bridge=bridge2 interface=ether2
add address=192.168.100.1/24 interface=bridge1 network=192.168.100.0
add address=192.168.200.1/24 interface=bridge2 network=192.168.200.0
add address=192.168.100.0/24 dns-server=192.168.100.1 gateway=192.168.100.1
add address=192.168.200.0/24 dns-server=192.168.200.1 gateway=192.168.200.1
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set vlan200 disabled=yes display-time=5s
set vlan100 disabled=yes display-time=5s
set "vlan 200i" disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set bridge2 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
/tool user-manager profile profile-limitation
add from-time=0s till-time=23h59m59s weekdays=
sunday,monday,tuesday,wednesday,thursday,friday,saturday
add from-time=0s limitation="1hr Limit" profile=hotspot till-time=23h59m59s
weekdays=sunday,monday,tuesday,wednesday,thursday,friday,saturday
/tool user-manager router
add coa-port=1700 customer=MikroTik disabled=no ip-address=127.0.0.1 log=
auth-fail name=router1 shared-secret=123 use-coa=no
/tool user-manager user
add customer=MikroTik disabled=no name=guest password=guest shared-users=1
wireless-enc-algo=none wireless-enc-key="" wireless-psk="
What kind of access point are you using? It should have ssıd mapping features with vlan…Also where is your hotspot stay? on vlan or eth2?
Help ! I need a full guide to configure VLAN with RB750 without an external switch.
Yes it will route between the VLANs because it is a router and by default it will route all connected networks. You can change that behaviour by adding filters in the forward chain in IP Firewall.
