I have VLANs and DHCP set up on pfsense. I’ve tried to extend VLAN 120 over the wifi but when connecting to the new virtual wireless interface “NAME_HERE_Guest” I don’t get any IP. If I plug in a PC on switch port 4 I do get an IP from the 120 VLAN.
Most likely my AP is missing some configuration setting because I’m very new to all of this.
pfsense ---- port: 8 (switch CSS610-8G-2S+IN) port: 7------ eth: 1 (AP cAP ac)
Switch:
AP:
# nov/12/2022 15:17:39 by RouterOS 6.48.6
add admin-mac=xxxx auto-mac=no comment=defconf name=bridge
add name=bridge_GuestVLAN
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=finland disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge \
ssid=NAME_HERE_2.4GHz wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=20/40/80mhz-XXXX country=finland disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=NAME_HERE wireless-protocol=802.11
add disabled=no mac-address=xxxx master-interface=wlan1 name=NAME_HERE_Guest ssid=NAME_HERE_Guest vlan-id=120 vlan-mode=use-tag wds-default-bridge=bridge \
wps-mode=disabled
/interface vlan
add interface=NAME_HERE_Guest name=GuestVLAN vlan-id=120
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=asdf1234
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge_GuestVLAN interface=GuestVLAN
add bridge=bridge interface=NAME_HERE_Guest
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.100.3/24 interface=ether1 network=192.168.100.0
add address=192.168.120.3/24 interface=bridge_GuestVLAN network=192.168.120.0
/ip dhcp-client
/ip dhcp-relay
add dhcp-server=192.168.120.1 disabled=no interface=bridge_GuestVLAN name=DHCP_Relay
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="Allow webconfig access from upstream" dst-address=192.168.100.3 dst-port=80 protocol=tcp src-address=192.168.100.16
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=xxx
/system package update
set channel=long-term
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\r\
\n :if ([system leds settings get all-leds-off] = \"never\") do={\r\
\n /system leds settings set all-leds-off=immediate \r\
\n } else={\r\
\n /system leds settings set all-leds-off=never \r\
\n }\r\
\n "
/tool mac-server
/tool mac-server mac-winbox
