VLAN And Hotspot
Dear All
Now I face a trouble with VLAN & Hotspot, need your help:_)
I am using RouterOS in an hotel, and using the hotspot to support Plug&Play for guest.
And now, I need create different VLAN ID to each room. The hotel has more than 400 rooms, so i need create more than 400 vlans , 1 room assign 1 vlan.
Now, I need setup VLAN Interface for each room,and setup address for each vlan interface and setup a lot of hotspot for each vlan interface,like this:
room1 — vlan1 — hotspot1
room2 — vlan2 — hotspot2
room3 — vlan3 — hotspot3
But as you know, the hotel have over 400 rooms,so i become crazy,The device can’t handle this.
I have try to bridge this vlans, and using 1 Dhcp Server And 1 hotspot, but does’nt work:
room1–vlan1—|
room2–vlan2—|----Bridge–Hotspot,
I have no ideal now, Does anybody can help me about this, very thanks…
What switches do you use? It would be 10x easier if you use a Cisco switch and just to put every client-end port into protected mode. That way no 2 rooms can comunicate with each other.
Just do a conf t
int fa 0/10
switchport protected
Mikrotik can run 250 VLANs.
and what happens with the rest?
Just do a conf t
int fa 0/10
I am not using vlan to stop the comunicate between each room, i am using vlan to identify the room, i mush assign different vlan id to each room. so ,
Mikrotik can run 4096 vlans, i have already setup 500 vlans, it worked
