VLAN Apple
I have an Engenius AP with a VLAN of 100 (public traffic) and 500 (private traffic) and an MT.
My IPAD2 on the private network cannot “see” the PC running iTUNES. Although it can stream movies from the same PC iTunes library.
Curious if the VLAN tagging is the issue. Something is getting blocked or dropped from the private wirless to the private wired network.
feb/10/1970 04:23:20 by RouterOS 5.6
software id = F1WZ-N8Z1
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
disabled=no forward-delay=15s l2mtu=1520 max-message-age=20s mtu=1500
name=bridge1 priority=0x8000 protocol-mode=none transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526
mac-address=00:0C:42:A0:4B:F2 mtu=1500 name=ether1-gateway speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“Private Interface” disabled=no full-duplex=yes l2mtu=1524 mac-address=
00:0C:42:A0:4B:F3 master-port=none mtu=1500 name=ether2-local speed=
100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
Hotspot disabled=no full-duplex=yes l2mtu=1524 mac-address=
00:0C:42:A0:4B:F4 master-port=none mtu=1500 name=ether3-local speed=
100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A0:4B:F5
master-port=none mtu=1500 name=ether4-local speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
“Management Port” disabled=no full-duplex=yes l2mtu=1524 mac-address=
00:0C:42:A0:4B:F6 master-port=none mtu=1500 name=ether5-local speed=
100Mbps
/interface vlan
add arp=enabled disabled=no interface=ether3-local l2mtu=1520 mtu=1500 name=
vlan500-private use-service-tag=no vlan-id=500
vlan100-hotspot use-service-tag=no vlan-id=100
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
switch-all-ports=no
set default authentication-types=“” eap-methods=passthrough group-ciphers=“”
group-key-update=5m interim-update=0s management-protection=disabled
management-protection-key=“” mode=none name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“”
static-sta-private-algo=none static-sta-private-key=“”
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“”
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
add dns-name=“” hotspot-address=10.5.50.1 html-directory=hotspot
name=hsprof1 rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot user profile
set default advertise=no name=default open-status-page=always shared-users=
250 status-autorefresh=1m transparent-proxy=yes
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m
name=default pfs-group=modp1024
add name=management_pool ranges=10.10.10.2-10.10.10.254
add name=private_pool ranges=192.168.1.150-192.168.1.199
add name=hs-pool-8 ranges=10.5.50.2-10.5.50.254
add name=dhcp_pool1 ranges=192.168.1.150-192.168.1.199
add address-pool=management_pool authoritative=after-2sec-delay
bootp-support=static disabled=no interface=ether5-local lease-time=3d
name=dhcp1
add address-pool=hs-pool-8 authoritative=after-2sec-delay bootp-support=
static disabled=no interface=vlan100-hotspot lease-time=1h name=dhcp4
add address-pool=private_pool authoritative=after-2sec-delay bootp-support=
static disabled=no interface=bridge1 lease-time=3d name=dhcp2
/ip hotspot
add address-pool=hs-pool-8 addresses-per-mac=2 disabled=no idle-timeout=5m
interface=vlan100-hotspot keepalive-timeout=none name=hotspot1 profile=
hsprof1
/port
set 0 baud-rate=115200 data-bits=8 flow-control=none name=serial0 parity=none
stop-bits=1
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=
default use-encryption=default use-mpls=default use-vj-compression=
default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=
default use-compression=default use-encryption=yes use-mpls=default
use-vj-compression=default
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter=“” redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=“”
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=
default
/snmp
set contact=“” enabled=no engine-id=“” location=“” trap-target=0.0.0.0
trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password=“”
authentication-protocol=MD5 encryption-password=“” encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514
src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto target=
remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet
boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes
enter-setup-on=any-key force-backup-booter=no silent-boot=no
/user group
add name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,web,sn
iff,sensitive,api,!ftp,!write,!policy” skin=default
add name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,password
,web,sniff,sensitive,api,!ftp,!policy” skin=default
add name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web,sniff,sensitive,api” skin=default
add bridge=bridge1 disabled=no edge=auto external-fdb=auto horizon=none
interface=ether2-local path-cost=10 point-to-point=auto priority=0x80
interface=vlan500-private path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
set ether2-local vlan-header=leave-as-is vlan-mode=fallback
set ether3-local vlan-header=leave-as-is vlan-mode=fallback
set ether4-local vlan-header=leave-as-is vlan-mode=fallback
set ether5-local vlan-header=leave-as-is vlan-mode=fallback
set switch1_cpu vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:85:7E:64:39:94
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=yes threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.1.1/24 comment=Private disabled=no interface=ether2-local
network=192.168.1.0
add address=10.10.10.1/24 comment=“Management Port” disabled=no interface=
ether5-local network=10.10.10.0
add address=10.5.50.1/24 comment=“hotspot network” disabled=no interface=
vlan100-hotspot network=10.5.50.0
/ip dhcp-client
add add-default-route=yes comment=“default configuration”
default-route-distance=1 disabled=no interface=ether1-gateway
use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=10.5.50.0/24 comment=“hotspot network” gateway=10.5.50.1
add address=10.10.10.0/24 comment=“Management Network” dns-server=10.10.10.1
gateway=10.10.10.1
add address=192.168.0.0/24 comment=“hotspot network” dns-server=192.168.1.1
gateway=192.168.0.1
add address=192.168.1.0/24 comment=“Private Network” dns-server=192.168.1.1
gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512 servers=x.145.232.4,x.144.49.30
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=passthrough chain=unused-hs-chain comment=
“place hotspot rules here” disabled=yes
add action=accept chain=input comment=“default configuration” disabled=no
protocol=icmp
add action=accept chain=input comment=Winbox disabled=no dst-port=8291
protocol=tcp
connection-state=established disabled=no in-interface=ether1-gateway
connection-state=related disabled=no in-interface=ether1-gateway
add action=drop chain=input comment=“default configuration” disabled=no
add action=masquerade chain=srcnat comment=“default configuration” disabled=
no out-interface=ether1-gateway
add action=masquerade chain=srcnat comment=“masquerade hotspot network”
disabled=no src-address=192.168.0.0/24
add action=masquerade chain=srcnat disabled=no src-address=192.168.2.0/24
disabled=no src-address=10.5.50.0/24
add action=accept chain=srcnat comment=DVR disabled=no dst-address=
192.168.1.201 dst-port=7100 protocol=tcp
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip hotspot user
add disabled=no name=admin password=“” profile=default
add disabled=no name=rnr password=rnr profile=default server=hotspot1
/ip neighbor discovery
set ether1-gateway disabled=no
set ether2-local disabled=no
set ether3-local disabled=no
set ether4-local disabled=no
set ether5-local disabled=no
set vlan500-private disabled=yes
set vlan100-hotspot disabled=yes
set bridge1 disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=
0.0.0.0
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=80
set ssh disabled=no port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1-gateway queue=ethernet-default
set ether2-local queue=ethernet-default
set ether3-local queue=ethernet-default
set ether4-local queue=ethernet-default
set ether5-local queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=RnR
/system logging
add action=memory disabled=no prefix=“” topics=info
add action=memory disabled=no prefix=“” topics=error
add action=memory disabled=no prefix=“” topics=warning
add action=echo disabled=no prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set address=0.0.0.0 from=<> password=“” port=25 user=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set (unknown) disabled=no interface=ether2-local
set (unknown) disabled=no interface=ether3-local
set (unknown) disabled=no interface=ether4-local
set (unknown) disabled=no interface=ether5-local
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number=“” channel=0 keep-max-sms=0 receive-enabled=no secret=“”
/tool sniffer
set file-limit=10 file-name=“” filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=all-frames
filter-stream=yes interface=all memory-limit=10 memory-scroll=yes
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
