struggling with proper VLAN set up. Basic home set-up. Eth2-4 will be for PCs and TV (which I’ll later add to separate VLAN) and 2x wifi.
Currently trying to set up wifi on VLAN 20 for guests. I can connect to wifi, proper IP, also torch shows some lines with Vlan Id 20, but unfortunately no internet access.
Any help is appreciated.
Thank you.
# feb/07/2023 22:19:25 by RouterOS 7.5
# software id = 8WTH-A6G4
# model = C53UiG+5HPaxD2HPaxD
# serial number =
add admin-mac=ZZZZZZZZZ auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
set [ find default-name=ether1 ] comment=Internet name=ether1_wan
set [ find default-name=ether2 ] comment=PC name=ether2_PC
set [ find default-name=ether3 ] comment=Other
set [ find default-name=ether4 ] comment=Other
set [ find default-name=ether5 ] comment=SonyTV name=ether5_SonyTV
/interface vlan
add interface=bridge name=interface_vlan20 vlan-id=20
add name=WAN
add name=LAN
add name=VLAN
/interface wifiwave2 security
add authentication-types=wpa2-psk name=AThome
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac configuration.country=USA .mode=ap .ssid="Ahsoka Tano 2" \
disabled=no name="Ahsoka Tano 2" security=AThome \
security.authentication-types=wpa2-psk
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac configuration.country=USA .mode=ap .ssid="Ahsoka Tano 5" \
disabled=no name="Ahsoka Tano 5" security=AThome \
add channel.band=5ghz-ax configuration.country=USA .mode=ap .ssid=\
"Ahsoka Tano 6" disabled=no mac-address=ZZZZZZ \
master-interface="Ahsoka Tano 5" name="Ahsoka Tano 6" \
security.authentication-types=wpa2-psk,wpa3-psk
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=20.10.10.2-20.10.10.254
add name=dhcp_pool2 ranges=30.10.10.2-30.10.10.254
add address-pool=dhcp interface=bridge name=defconf
add address-pool=dhcp_pool1 interface=interface_vlan20 name=dhcp_vlan20
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2_PC
add bridge=bridge comment=defconf interface=ether5_SonyTV
add bridge=bridge comment=defconf interface="Ahsoka Tano 5"
add bridge=bridge comment=defconf interface="Ahsoka Tano 2"
add bridge=bridge interface="Ahsoka Tano 6" pvid=20
/interface bridge vlan
add bridge=bridge tagged="Ahsoka Tano 6,bridge" vlan-ids=20
add interface=bridge list=LAN
add interface=ether1_wan list=WAN
add interface=interface_vlan20 list=VLAN
192.168.88.0
add address=20.10.10.1/24 interface=interface_vlan20 network=20.10.10.0
/ip dhcp-client
add comment=defconf interface=ether1_wan
add address=20.10.10.0/24 gateway=20.10.10.1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=USA
/tool mac-server
/tool mac-server mac-winbox
