VLAN Between 2 Bridges (With Hardware Offloading)
Hi All,
I am struggling a bit to get to get my head around a VLAN setup I need to implement.
At our datacenter we have a CCR1036 (router A), with no bridge.
At another location we have a CRS317 (in RouterOS Router B) that is bridging all ports.
These two routers are connected via a MetroNet Fiber link.
I need to link these two routers via a VLAN eg. vlan id 12.
Now just creating the VLAN interface on each side, and adding the vlan interface to the bridge of Router B works fine, but then I see there is no Hardware offloading.
What would be the correct way to configure the stated link, that would allow hardware offloading on the VLAN interfaces?
CPU usage on Router B is quite high (25%) and thats with only around 150Mbps worth of traffic over VLAN.
Any help would be greatly appreciated
How did you add the VLAN to the bridge? Can you please supply the config (without any personal information)?
I think VLAN filtering should be handled by the bridge, perhaps have a look at this topic:
Thanks for the info so far. Below is the config of the 2 routers.
I basically just added an vlan on each router under interface
Then on router B I added the vlan interface to the bridge ports.
But on the bridge I am not getting the H flag on vlan interface, and router A does not have a bridge.
Router A
# aug/11/2022 12:58:52 by RouterOS 7.2.1
# software id = I3CR-EP9C
# model = CCR1036-8G-2S+
# serial number = D83A0D827F76
/interface wireguard
add listen-port=9515 mtu=1420 name=wireguard1
/interface vlan
add comment="METRO/DFA -> CJ/NEUHOFF" interface=sfp-sfpplus2 name=VLAN:11 \
    vlan-id=11
add comment="MONITORING VLAN" interface=sfp-sfpplus2 name=vlan10 vlan-id=10
add name=WAN
add name=LAN
/interface lte apn
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256,aes-192,aes-128,3des
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1
add name=dhcp_pool0 ranges=192.168.253.10-192.168.253.254
add address-pool=dhcp_pool0 interface=VLAN:11 name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
/ppp profile
set *0 change-tcp-mss=no local-address=100.64.0.1
add local-address=192.168.250.1 name=management-prof remote-address=\
    dhcp_pool0
add change-tcp-mss=yes name=dcpppoeProfile
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/snmp community
set [ find default=yes ] addresses=::/0,192.168.250.1/32
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,rest-api"
/interface bridge filter
add action=drop chain=forward disabled=yes dst-port=67-68 ip-protocol=udp \
    mac-protocol=ip
/interface bridge settings
set use-ip-firewall-for-pppoe=yes
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface l2tp-server server
set caller-id-type=number use-ipsec=yes
add interface=sfp-sfpplus1 list=WAN
add list=LAN
/interface ovpn-server server
set auth=sha1,md5
/interface pppoe-server server
add service-name=VLAN11_PPPOE
add disabled=no interface=VLAN:11 service-name=VLAN10_PPPOE
add address=100.64.0.1/18 comment=defconf interface=ether1 network=100.64.0.0
add address=154.72.6.54/30 interface=sfp-sfpplus1 network=154.72.6.52
add address=192.168.250.1/23 interface=VLAN:11 network=192.168.250.0
add address=192.168.252.1/23 interface=VLAN:11 network=192.168.252.0
add address=192.168.248.1/24 interface=wireguard1 network=192.168.248.0
add address=192.168.254.1/24 interface=vlan10 network=192.168.254.0
add address=192.168.252.0/23 gateway=192.168.252.1 netmask=23
Router B
# aug/11/2022 12:57:11 by RouterOS 7.2.1
# software id = SBUJ-R6RJ
# model = CRS309-1G-8S+
# serial number = CB790CE2D700
add admin-mac=48:8F:5A:10:1A:85 auto-mac=no name=bridge1
set [ find default-name=ether1 ] l2mtu=1592
set [ find default-name=sfp-sfpplus1 ] l2mtu=1592
set [ find default-name=sfp-sfpplus2 ] comment=Airfiber l2mtu=1592 speed=\
    100Mbps
set [ find default-name=sfp-sfpplus3 ] advertise=\
    10M-half,100M-half,100M-full,1000M-half,1000M-full comment="Sec 1" l2mtu=\
    1592
set [ find default-name=sfp-sfpplus4 ] comment="Sec 2" l2mtu=1592 speed=\
    10Mbps
set [ find default-name=sfp-sfpplus5 ] comment="AHA ptp" l2mtu=1592
set [ find default-name=sfp-sfpplus6 ] auto-negotiation=no comment=\
    "Neuhoff Fiber" l2mtu=1592
set [ find default-name=sfp-sfpplus7 ] full-duplex=no l2mtu=1592 speed=\
    100Mbps
set [ find default-name=sfp-sfpplus8 ] l2mtu=1592 rx-flow-control=auto \
    tx-flow-control=auto
/interface vlan
add disabled=yes interface=sfp-sfpplus1 name=vlan10-reflex vlan-id=10
add interface=sfp-sfpplus1 name=vlan11-reflex vlan-id=11
add name=WAN
add name=LAN
/interface lte apn
/port
set 0 name=serial0
/routing ospf area
/user group
add bridge=bridge1 ingress-filtering=no interface=ether1
add bridge=bridge1 ingress-filtering=no interface=sfp-sfpplus2
add bridge=bridge1 ingress-filtering=no interface=sfp-sfpplus3
add bridge=bridge1 ingress-filtering=no interface=sfp-sfpplus4
add bridge=bridge1 ingress-filtering=no interface=sfp-sfpplus5
add bridge=bridge1 ingress-filtering=no interface=sfp-sfpplus6
add bridge=bridge1 ingress-filtering=no interface=sfp-sfpplus7
add bridge=bridge1 ingress-filtering=no interface=sfp-sfpplus8
add bridge=bridge1 ingress-filtering=no interface=vlan10-reflex
add bridge=bridge1 ingress-filtering=no interface=vlan11-reflex
set discover-interface-list=all
/ip settings
/ipv6 settings
set disable-ipv6=yes
add interface=ether1 list=WAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
add interface=sfp-sfpplus5 list=LAN
add interface=sfp-sfpplus6 list=LAN
add interface=sfp-sfpplus7 list=LAN
add interface=sfp-sfpplus8 list=LAN
set auth=sha1,md5
add address=192.168.252.55/23 interface=bridge1 network=192.168.252.0
/ip dhcp-client
add add-default-route=no disabled=yes interface=bridge1
set servers=8.8.8.8,8.8.4.4
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.252.1 \
    pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
    target-scope=10
/snmp
set enabled=yes
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name=DC-Neuhoff-Switch
/system ntp client
set enabled=yes
/system ntp client servers
add address=162.159.200.123
/system routerboard settings
set boot-os=router-os boot-protocol=dhcp
/system swos
set address-acquisition-mode=static allow-from-ports=\
    p1,p2,p3,p4,p5,p6,p7,p8,p9 identity=DC-Neuhoff-Switc static-ip-address=\
    192.168.250.88
/tool bandwidth-server
set authenticate=no
