I’m trying to setup a trunk between router (RB951G-2HnD) and a switch (RB260GS).
In my design:
router-ether5 <=> trunk <=> switch-port1
Switch setup:
Router setup:
# sep/07/2014 11:30:08 by RouterOS 6.18
# software id = 80AC-XWGX
add l2mtu=1594 name=bridge-local
/interface wireless
set [ find default-name=wlan1 ] l2mtu=2290
set [ find default-name=ether1 ] comment=WAN name=ether1-WAN-ADSL
set [ find default-name=ether2 ] comment=LAN name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] name=ether5-trunk
/ip neighbor discovery
set ether1-WAN-ADSL comment=WAN
set ether2-master comment=LAN
/interface vlan
add interface=ether5-trunk l2mtu=1594 name=vlan1 vlan-id=1
add interface=ether5-trunk l2mtu=1594 name=vlan10 vlan-id=10
add interface=ether5-trunk l2mtu=1594 name=vlan20 vlan-id=20
add name=dhcp_pool1 ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp_pool1 disabled=no interface=bridge-local name=dhcp1
add bridge=bridge-local interface=ether2-master
add bridge=bridge-local interface=vlan1
add bridge=bridge-local interface=vlan20
add address=192.168.1.1/24 interface=ether2-master network=192.168.1.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=ether1-WAN-ADSL
add address=192.168.1.0/24 gateway=192.168.1.1
/ip upnp
set allow-disable-external-interface=no
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes primary-ntp=82.197.0.130
Pretty basic setup, but something doesn’t work tough.
The clients on VLAN20 can set successfully the DHCP address, but cannot see the internet, nor other devices outside of VLAN20.
What Im missing?
