VLAN, BRIDGE and Point 2 Point Link
Hello
Ive been using RB’s for some time now, and my normal setup works a treat - however, im having to step outside of my comfort zone with this one.
I have an RB1100 running hotspot server, with 5 APs connected (wired)
The RB1000 and APS all run a mgmt vlan and the hotspot vlan
I now need to expand the network, adding a 6th AP which will be wireless as its not possible to wire it back to the RB1100.
Ive added a second WLAN card to one of the APS, with the plan to create a link from there to the 6th AP (which will also be dual WAN).
I then tried to bridge the WLAN2 with the MGMT and HOTSPOT vlans to allow me to send them to the remote AP, however, I am unable to add the HOTSPOT vlan as its already bridged with WLAN1.
How do i go about sending my two VLANS over the new link?
Thank you.
