I created a vlan on eth2 (vlan101) and then bridged the new vlan to wireless. I have a bridge from eth2 to eth1, to pass untagged traffic over ethernet. However, as soon as I create the second bridge, it breaks the vlan. I can see vlan tagged traffic come in on eth2, but it doesn’t get passed on to the vlan101 interface. It looks like a bug, but it could also be that I’m implementing this incorrectly. Anyone have a solution?
Hello!
My case is as follows:
I have a PC Running Mikrotik - “have done downgrade to version 4.17, climbed to 05.26 and currently is in the 6.33.3 version” when I set up a VLAN between this mikrotik and NANOSTATIOM M5 just does not work, I thought it could be hardware problem, I set up another pC and used the same HD, did not work, installed a new HD in the pC and installed the version that is for use with 24 hours also did not work, however when I do the same settings in a RB450G VLAN works immediately!
Can anyone tell what should I do to solve the problem? this has happened to any of you?
Already many thanks to all!
