VLAN can not ping Gateway
I have followed the guide here;
In order to set up two VLANs on my RB2011.
I have confirmed that a host will get the right IP from the DHCP server for the VLAN it should be on.
However that same host is not able to ping its Gateway, and therefore get out to the internet.
Any ideas would be great :slight_smile:
Current config (minus sensitive info )
Sorry if formatting is poor,
jun/22/2020 20:03:50 by RouterOS 6.46.6
software id = RSMW-YDSZ
model = RB2011UiAS-2HnD
serial number = B9090B80C4B6
add admin-mac=C4:AD:34:2D:4C:CE auto-mac=no comment=defconf name=Home
add name=Lab
set [ find default-name=ether1 ] advertise=10M-full,100M-full,1000M-full
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="united kingdom" disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid="Stay off" wireless-protocol=802.11
/interface vlan
add interface=Lab name=VLAN10_Desktop vlan-id=10
add interface=Lab name=VLAN20_Server vlan-id=20
/interface ethernet switch
set 0 name=Home
set 1 name=Lab
set 6 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 7 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 8 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.2-192.168.88.254
add name=POOlab ranges=192.168.100.100-192.168.100.200,192.168.50.2-192.168.50.254
add name="Pool VLAN50" ranges=192.168.50.2-192.168.50.254
add name=POOL10 ranges=192.168.10.100-192.168.10.200
add name=POOL20 ranges=192.168.20.100-192.168.20.200
add address-pool=dhcp disabled=no interface=Home name=defconf
add address-pool=POOlab disabled=no interface=Lab name=DHCPlab
add address-pool=POOL10 disabled=no interface=VLAN10_Desktop name=DHCP10
add address-pool=POOL20 disabled=no interface=VLAN20_Server name=DHCP20
add bridge=Home comment=defconf interface=ether2
add bridge=Home comment=defconf interface=ether3
add bridge=Home comment=defconf interface=ether4
add bridge=Home comment=defconf interface=ether5
add bridge=Lab comment=defconf interface=ether6
add bridge=Lab comment=defconf interface=ether7
add bridge=Lab comment=defconf interface=ether8
add bridge=Lab comment=defconf interface=ether9
add bridge=Lab comment=defconf interface=ether10
add bridge=Home comment=defconf interface=sfp1
add bridge=Lab comment=defconf interface=wlan1
add ports=ether7,Lab-cpu switch=Lab vlan-id=10
add ports=ether8,Lab-cpu,ether6 switch=Lab vlan-id=20
add comment=defconf interface=Home list=LAN
add interface=Lab list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
add address=192.168.100.1/24 interface=Lab network=192.168.100.0
add address=192.168.1.137/24 interface=ether1 network=192.168.1.0
add address=192.168.10.1/24 interface=VLAN10_Desktop network=192.168.10.0
add address=192.168.20.1/24 interface=VLAN20_Server network=192.168.20.0
/ip dhcp-client
add address=192.168.10.0/24 dns-server=8.8.8.8 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=8.8.8.8 gateway=192.168.20.1
add address=192.168.88.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4 gateway=192.168.88.1 netmask=24
add address=192.168.100.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.100.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add action=drop chain=input comment="Custom: Lab Gateway isolation" disabled=yes dst-address=192.168.100.1 in-interface=Home log=yes
add action=drop chain=input disabled=yes dst-address=192.168.88.1 in-interface=Lab log=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=forward comment="lab exception" disabled=yes dst-address=192.168.100.1 src-address=192.168.100.0/24
add action=drop chain=forward comment="Custom: Lab Isolation" disabled=yes dst-address=192.168.100.0/24 src-address=192.168.88.0/24
add action=drop chain=forward disabled=yes dst-address=192.168.88.0/24 log=yes src-address=192.168.100.0/24
add action=drop chain=forward disabled=yes dst-address=192.168.100.0/24 log=yes src-address=192.168.100.0/24
add distance=1 gateway=192.168.1.254
/system clock
set time-zone-name=Europe/London
/tool mac-server
/tool mac-server mac-winbox
