I’m new to RouterOS. At work we have a Mictotik router that used to be managed by somebody else. I’m setting up a new AP with a guest network. WAN is on ‘ether1’, our main switch is connected to ‘ether5’ and to test/keep it separate, the AP is connected to ether2. I followed a guide to create the guest VLAN.
At the moment, I can connect to the AP, the DHCP server gives me an IP from the correct pool. I can ping devices on the other subnet (192.168.20.0/24) but can’t ping the gateway (10.20.20.1) and can’t get out to the internet. I’ve obviously done something wrong but I’m struggling to work out what. Can anybody see anything wrong in our config?
Cheers,
add auto-mac=no fast-forward=no name=bridge-local \
vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether3 ] name=ether3
set [ find default-name=ether4 ] name=ether4-slave-local
set [ find default-name=ether5 ] name=ether5-LAN
set [ find default-name=ether6 ] name=ether6
set [ find default-name=ether7 ] name=ether7
set [ find default-name=ether8 ] name=ether8-slave-local
set [ find default-name=ether9 ] name=ether9-slave-local
set [ find default-name=ether10 ] name= ether10-slave-local
/interface vlan
add interface=bridge-local name=vlan2 vlan-id=200
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-gateway name=IPVN \
user=xxxxxxx
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/interface lte apn
add name=dhcp_pool3 ranges=10.20.20.2-10.20.20.20
add address-pool=dhcp_pool3 interface=vlan2 name=dhcp1
/port
set 0 name=serial0
/ppp profile
set *0 change-tcp-mss=no
set *FFFFFFFE change-tcp-mss=no
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
add addresses=::/0 name=123
add bridge=bridge-local ingress-filtering=no interface=ether2
add bridge=bridge-local ingress-filtering=no interface=ether6
add bridge=bridge-local hw=no ingress-filtering=no interface=sfp1
add bridge=bridge-local ingress-filtering=no interface=wlan1
add bridge=bridge-local ingress-filtering=no interface=ether3
add bridge=bridge-local ingress-filtering=no interface=ether4-slave-local
add bridge=bridge-local ingress-filtering=no interface=ether5-LAN
add bridge=bridge-local ingress-filtering=no interface=ether8-slave-local
add bridge=bridge-local ingress-filtering=no interface=ether9-slave-local
add bridge=bridge-local ingress-filtering=no interface=ether10-slave-local
set discover-interface-list=all
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge-local tagged=ether2,bridge-local vlan-ids=200
add address=192.168.20.254/24 comment="default configuration" interface=\
bridge-local network=192.168.20.0
add address=10.20.20.1/24 interface=vlan2 network=10.20.20.0
add address=10.20.20.0/24 dns-server=10.20.20.1,8.8.8.8 gateway=\
10.20.20.1
/ip firewall mangle
add action=change-mss chain=forward new-mss=1350 out-interface=IPVN \
passthrough=yes protocol=tcp tcp-flags=syn
add disabled=no dst-address=xxxx gateway=bridge-local pref-src=\
xxxx
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
