Afternoon, I am installing a CRS tomorrow, can someone just verify my config.
I need port 1 an 2 untagged on 2000 and tagged on 135 and 2002
Port 3 tagged for 135, 2000, 2002
Does the bridge need to be tagged on all vLans?
model = CRS309-1G-8S+
set [ find default-name=sfp-sfpplus1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,10000M-full
auto-negotiation=no l2mtu=1500 name=sfp-sfpplus1-LD5-R1 speed=10Gbps
set [ find default-name=sfp-sfpplus2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full
auto-negotiation=no l2mtu=1500 name=sfp-sfpplus2-LD5-R2 speed=10Gbps
set [ find default-name=sfp-sfpplus3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full
auto-negotiation=no l2mtu=1500 name=sfp-sfpplus3-SSE10GB speed=10Gbps
add bridge=bridgeLocal comment=defconf interface=sfp-sfpplus1-LD5-R1 pvid=2000
add bridge=bridgeLocal comment=defconf interface=sfp-sfpplus2-LD5-R2 pvid=2000
add bridge=bridgeLocal comment=defconf interface=sfp-sfpplus3-SSE10GB
add bridge=bridgeLocal comment=defconf interface=sfp-sfpplus4
add bridge=bridgeLocal comment=defconf interface=sfp-sfpplus5
add bridge=bridgeLocal comment=defconf interface=sfp-sfpplus6
add bridge=bridgeLocal comment=defconf interface=sfp-sfpplus7
add bridge=bridgeLocal comment=defconf interface=sfp-sfpplus8
/interface bridge vlan
add bridge=bridgeLocal tagged=sfp-sfpplus3-SSE10GB,bridgeLocal untagged=sfp-sfpplus1-LD5-R1,sfp-sfpplus2-LD5-R2 vlan-ids=
2000
add bridge=bridgeLocal tagged=sfp-sfpplus1-LD5-R1,bridgeLocal,sfp-sfpplus2-LD5-R2,sfp-sfpplus3-SSE10GB vlan-ids=222
add bridge=bridgeLocal tagged=sfp-sfpplus1-LD5-R1,bridgeLocal,sfp-sfpplus2-LD5-R2,sfp-sfpplus3-SSE10GB vlan-ids=2002
tdw
December 6, 2020, 12:56pm
2
There is no /interface bridge section to create the bridge.
Only if you wish to access services on the Mikrotik itself from them, e.g. management access.
anav
December 6, 2020, 1:22pm
3
Not enough info to make any determinations worth discussion.
Please post config
Also a network diagram is helpful to understand what is on the receiving end/functionality of the devices the vlans are headed towards.
Here is the fully config not much different.
I don’t have a diagram to hand but i just need need port 1 an 2 untagged on 2000 and tagged on 135 and 2002, Port 3 tagged for 135, 2000, 2002
serial number = BE140AB02200
add admin-mac=74:4D:28:AD:A5:CB auto-mac=no comment=defconf name=bridgeLocal
set [ find default-name=sfp-sfpplus1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,10000M-full auto-negotiation=no l2mtu=1500 name=sfp-sfpplus1-LD5-R1
speed=10Gbps
set [ find default-name=sfp-sfpplus2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full auto-negotiation=no l2mtu=1500 name=
set [ find default-name=sfp-sfpplus3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full auto-negotiation=no l2mtu=1500 name=
/ip hotspot profile
add bridge=bridgeLocal tagged=sfp-sfpplus3-SSE10GB,bridgeLocal untagged=sfp-sfpplus1-LD5-R1,sfp-sfpplus2-LD5-R2 vlan-ids=2000
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip service
set telnet disabled=yes
set www disabled=yes
set ssh address=172.16.97.0/24,172.16.90.0/24,192.168.5.0/24
set api disabled=yes
set winbox address=172.16.97.0/24,172.16.90.0/24,192.168.5.0/24
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/London
/system identity
set name=LD5_10G_Interconnect
/system ntp client
set enabled=yes server-dns-names=0.uk.pool.ntp.org ,1.uk.pool.ntp.org
/system routerboard settings
set boot-os=router-os
[admin@LD5_10G_Interconnect] >
sindy
December 6, 2020, 3:39pm
5
Nevertheless, it does show the important part which was missing in the OP.
vlan-filtering must be activated on the bridge so that VLAN tagging and untagging worked, and your /interface bridge section shows it is currently not. Yes, the name of the behaviour is a bit confusing, it controls more handling than just filtering.
The manual has more details.
Other than this, there is only a discrepancy between your text description:
I just need port 1 and 2 untagged on 2000 and tagged on 135 and 2002, Port 3 tagged for 135 , 2000, 2002
and the configuration:
anav
December 6, 2020, 6:25pm
6
Geez Sindy, can you leave me the easy ones, and you take the ones that really need networking understanding
