First off, need to say i’m new to MikroTik products, in short I picked up a PowerBox and a 450G. I’ve been getting some configs going on them and thought I had an understanding on how the VLANs worked in RouterOS. I’ve been setting up bridges tied to the VLANs and ports. In attending to configure a VLAN on the PowerBox I can’t for the life of me to get it to work. In reviewing the documentation I noticed VLANs in the switch section. Long and short i’m now confused, do I setup the VLANs under the Switch section or the Interface section? As an example, I have a device on Eth3 on the Powerbox. I need untagged, VLAN 1 and VLAN 2. I would like to connect those to a bridge so I can change the those VLANs going upstream. As an example, VLAN1 on Eth3 connects to bridge1, eth1 has VLAN 200 which is connected to bridge1. So basically VLAN1 in from eth3 and out eth1 as VLAN 200.
-Chris
