I created 6 VLAN and assigned IP address to each VLAN interface. I was able to talk to any equipment in each VLAN except VLAN1. I wanted to know what I did wrong
the info to access the router
IP: 217.64.101.58
user: mikro
passwd: 1234
thank you!
IP: 217.64.101.58
user: mikro
passwd: 1234
thank you!
try changing vlan-id to other value than 1, some switches/routers may not pass this tagged traffic
If VLAN 1 is native to your switch then VLAN1 packets will not be tagged going across the trunk.
You don’t need to create a VLAN1 on your router.
Put the IP address you want to use for VLAN1 of your switch on the routers ethernet interface that is connected to the switch.
You will then want to create VLAN interfaces off from the ethernet interface going to the switch for switch ports assigned to other VLANS greater than 1.
