VLAN config: RB2011UiAS-2HnD to L009UiGS-2HaxD
I have a well loved RB2011UiAS-2HnD that is starting to flake out. It will stop routing select packets, when it feels like it. Really strange.
I am replacing it with a L009UiGS-2HaxD and attempting to move over the configuration and do some cleanup.
I can’t get vlans working on the L009UiGS-2HaxD. I am starting off with getting vlan2 working. A laptop plugged into ether7 can not get a DHCP address, or ping 192.168.2.1 the gateway if I assign it a static address. I have not teste vlan3 and vlan4 yet, but they will be internal.
Am I missing something?
There is a lot more cruft below that I have not gotten to testing yet, so please excuse any weird stuff. ether5-8 should be like an access port, and ether3-Server and spf1 will by a hybrid trunk port.
# 1970-01-01 18:30:38 by RouterOS 7.12.2
# software id = 33UN-D54T
# model = L009UiGS-2HaxD
# serial number = <snip>
add admin-mac=D4:01:C3:5E:C8:D6 auto-mac=no comment=defconf name=bridge vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-StarLink
set [ find default-name=ether2 ] name=ether2-LTE
set [ find default-name=ether3 ] name=ether3-Server
/interface wireguard
add listen-port=51820 mtu=1400 name=wireguard1
/interface vlan
add interface=bridge name=vlan2 vlan-id=2
add interface=bridge name=vlan3 vlan-id=3
add interface=bridge name=vlan4 vlan-id=4
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=internal ranges=192.168.1.100-192.168.1.200
add name=vlan2 ranges=192.168.2.2-192.168.2.250
add name=vlan4 ranges=192.168.4.2-192.168.4.100
add name=vlan3 ranges=192.168.3.2-192.168.3.250
add address-pool=default-dhcp disabled=yes interface=bridge lease-time=10m name=defconf
add address-pool=vlan4 authoritative=after-2sec-delay interface=vlan4 lease-time=10m name=vlan4
add address-pool=internal bootp-support=none disabled=yes interface=bridge lease-time=1h name=dhcp
add address-pool=vlan3 interface=vlan3 lease-time=10m name=vlan3
add address-pool=vlan2 interface=vlan2 name=vlan2
/port
set 0 name=serial0
/snmp community
set [ find default=yes ] addresses=192.168.1.23/32
/system logging action
set 3 bsd-syslog=yes remote=192.168.1.23
add bridge=bridge interface=ether4
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge ingress-filtering=no interface=ether3-Server
add bridge=bridge interface=ether5 pvid=2
add bridge=bridge interface=ether6 pvid=2
add bridge=bridge interface=ether7 pvid=2
add bridge=bridge interface=ether8 pvid=2
/interface bridge vlan
add bridge=bridge tagged=ether3-Server,sfp1 untagged=ether5,ether6,ether7,ether8 vlan-ids=2
add bridge=bridge tagged=ether3-Server,sfp1 vlan-ids=3
add bridge=bridge tagged=ether3-Server,sfp1 vlan-ids=4
add comment=defconf interface=ether1-StarLink list=WAN
add address=192.168.1.26/24 comment=defconf interface=bridge network=192.168.1.0
add address=192.168.2.1/24 interface=vlan2 network=192.168.2.0
add address=192.168.3.1/24 comment=ceph interface=vlan3 network=192.168.3.0
add address=192.168.4.1/24 interface=vlan4 network=192.168.4.0
add address=10.7.0.5/24 interface=wireguard1 network=10.7.0.0
/ip dhcp-client
add add-default-route=no comment=LTE interface=ether2-LTE use-peer-dns=no use-peer-ntp=no
add address=192.168.1.0/24 dns-server=192.168.1.23,192.168.1.25 domain=<snip>.net gateway=192.168.1.25 netmask=24 ntp-server=192.168.1.23
add address=192.168.2.0/24 dns-server=192.168.2.1 domain=<snip>.net gateway=192.168.2.1 netmask=24 ntp-server=192.168.1.23
add address=192.168.3.0/24 dns-server=192.168.3.1 domain=<snip>.net gateway=192.168.3.1 netmask=24 ntp-server=192.168.1.23
add address=192.168.4.0/24 dns-server=192.168.4.1 domain=<snip>.net gateway=192.168.4.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.4.4.8
add action=masquerade chain=srcnat out-interface=ether2-LTE
add action=masquerade chain=srcnat out-interface=ether1-StarLink
add action=masquerade chain=srcnat out-interface=wireguard1
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/snmp
set enabled=yes
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=MikroTikBatteryRoom2
/system logging
set 0 action=remote
set 1 action=remote
set 2 action=remote
set 3 action=remote
add action=remote prefix="Route Change" topics=route
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes manycast=yes
/system ntp client servers
add address=108.61.73.243
add address=207.140.111.251
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
Bridge port has to be tagged member of any VLANs which there are corresponding vlan interfaces.
in the /bridge vlan menu also insert the bridge itself as an interface tagged in the various vlans
Recommend whatever you are doing with bridge and dhcp, simply move subnet to another vlan and thus the bridge just does bridging.
Not sure also why you have 3 vlans and 5 pools…
