VLAN configuration between SwOS / RouterOS CRS2xx not working
after spending many hours, in which I crashed my home network many times, I need your help. I want to configure one new VLAN in addition to my existing untagged VLAN. Both networks should be able to communicate via InterVLAN Routing through my RouterOS switch. I’m using multiple SwOS switches and one RouterOS switch.
Issues:
  • Clients in VLAN 2, connected to my SwOS access switch, are not able to reach the RouterOS IP in VLAN 2
  • Connection of untagged traffic stops working, as soon as I configure “set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports”
Physical connection of my hardware, used for testing:
  • PC in untagged VLAN → Mikrotik CRS305 (SwOS) → Mikrotik CRS210 (RouterOS) → Internet Gateway
  • PC in VLAN 2 → Mikrotik CRS305 (SwOS) → Mikrotik CRS210 (RouterOS) → Internet Gateway
  • Both PCs connected to the same Access Switch, SwOS VLAN config works
SwOS Config (Access Switch on RouterOS port sfp-sfpplus1)
  • Port 1 (ETH0) = PC untagged in VLAN 2
  • Port 2 (SFP1) = PC untagged (should be VLAN 1, since PVID is 1?)
  • Port 3 (SFP2) = Uplink to RouterOS
RouterOS Config
  • Port ether1 = Uplink to Internet GW
  • Port sfp-sfpplus1= Uplink to my first SwOS switch
  • Port sfpplus2= Uplink to my second SwOS switch
add name=bridge
add bridge=bridge interface=ether1 hw=yes
add bridge=bridge interface=sfp-sfpplus1 hw=yes
add bridge=bridge interface=sfpplus2 hw=yes
/interface ethernet switch ingress-vlan-translation
add ports=ether1 customer-vid=0 new-customer-vid=1 sa-learning=yes
add ports=sfp-sfpplus1 customer-vid=0 new-customer-vid=1 sa-learning=yes
add ports=sfpplus2 customer-vid=0 new-customer-vid=1 sa-learning=yes
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether1sfp-sfpplus1,sfpplus2 vlan-id=1
add tagged-ports=ether1,sfp-sfpplus1,sfpplus2 vlan-id=2
add ports=ether1,sfp-sfpplus1,sfpplus2 vlan-id=1 learn=yes
add ports=ether1,sfp-sfpplus1,sfpplus2 vlan-id=2 learn=yes
/interface vlan
add interface=bridge vlan-id=1 name=vlan1
add interface=bridge vlan-id=2 name=vlan2
add address=192.168.2.254/24 interface=vlan2
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether1,sfp-sfpplus1,sfpplus2
Following guide was used for my RouterOS configuration: https://wiki.mikrotik.com/wiki/Manual:Basic_VLAN_switching#CRS1xx.2FCRS2xx_series_switches
Problem solved.
It was needed to add "switch1-cpu", to get InterVLAN routing working.
Following config changes were made:
Add VLAN to ports
add ports=switch1-cpu,ether1,sfp-sfpplus1,sfpplus2 vlan-id=1 learn=yes
add ports=switch1-cpu,ether1,sfp-sfpplus1,sfpplus2 vlan-id=2 learn=yes
Add trunk ports
add tagged-ports=switch1-cpu,ether1sfp-sfpplus1,sfpplus2 vlan-id=1
add tagged-ports=switch1-cpu,ether1,sfp-sfpplus1,sfpplus2 vlan-id=2
