VLAN Configuration Help on CRS212-1G-10S-1S+
Hi all,
Need help on achieving below vlan config scenario :
CCR1036 configured (Vlan 10 & Vlan 20 on sfp1)
Vlan 10 (Running pppoe service)
Vlan 20 (Running Hotspot)
CCR1036 (sfp1) connected to CRS212-1G-10S-1S+ (sfp1)
Now i want to use CRS212 (sfp1) port as uplink to CCR and use rest of the CRS212 sfp ports as access ports which will be connected to various P2P and Mikrotik Sectors. We need to deliver both services (pppoe & hotspot) on each sector or over p2p to other bts and then to sectors on those and use them on client sxt as per convenience. Some clients would be using pppoe and some would be using hotspot service.
hope i have able to explain the scenario. Any help will be welcome.
CRS Vlan configuration is what i see is not documented properly. Need some expert advice.
CRS port based VLAN example #1 shows how to configure VLAN trunk ports and VLAN access ports which are required in your setup.
http://wiki.mikrotik.com/wiki/Manual:CRS_examples#Port_Based_VLAN
Is it possible that i can pass multiple vlans on the same access port going forward to Basebox5 Sectors ?
  1. Will the access ports be configured on CRS or it has to be taken to the Basebox5 and terminate their.
  2. Also what needs to be done in case where on the client SXT i need to configure particular vlan only whereas on the other client SXT a different vlan but both connecting through the same sector Basebox5.
It would be nice if examples are explained by command.
