I think I need a VLAN to accomplish what I need, but unsure how to configure using WebFig.
I have a Routerboard 750GL, WebFig v6.15
Port 2 is LAN with DHCP: 10.2.162.1
Port 3 is LAN with DHCP: 10.2.163.1
I need the gateway for each (10.2.163.254 & 10.2.162.254) to be accessible through another port - like port 5 or port 1.
I think I need VLAN on port 1 or port 5 to accomplish this, but have only manged to brick my routerboard when trying to configure. I have DHCP server working properly for each. But, unsure if I need to somehow add both DHCP servers to their own VLANs.
Any help much appreciated. I’d like to use WebFig, but will take command line at this point.
Thanks, but the simple example is a bit different than what I’m trying to do. Attached is a picture of what I’m trying to accomplish. I need both vlans to talk to their gateway through another port (5 in this example) because there is a filter in between the the MikroTik and the Cisco that needs to filter based on subnet.
Thanks,
-Bill
