Hello all,
I have a problem with VLAN configuration on my new MikroTik router.
main idea:
- have VLAN 20 on ports erher2-ether7 as untagged
- have the rest of the VLANs tagged on ports erher3-ether7
- have vlan1 untagged on port ether8 (it works)
- have all vlan tagged on port ether2 and sfp-sfpplus1 (maybe vlan1 untagged, but not necessary)
The Internet works fine for ether8
Now 2 raspberry pi connected to port ether2 and port ether3
Both hosts have no DHCP IP received.
add frame-types=admit-only-untagged-and-priority-tagged name=BridgeShared vlan-filtering=yes
add admin-mac=48:A9:8A:9F:B4:69 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name="[0] WAN Uplink"
set [ find default-name=sfp-sfpplus1 ] name="[1] LAN 10G"
set [ find default-name=ether2 ] name="[2] LAN 1G"
set [ find default-name=ether3 ] name="[3] ether3"
set [ find default-name=ether4 ] name="[4] ether4"
set [ find default-name=ether5 ] name="[5] ether5"
set [ find default-name=ether6 ] name="[6] ether6"
set [ find default-name=ether7 ] name="[7] ether7"
set [ find default-name=ether8 ] name="[8] MGMT"
/interface vlan
add interface=BridgeShared name=VLAN-10 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.10.0.151-10.10.0.200
add name=DMZ ranges=10.10.10.110-10.10.10.200
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
add add-arp=yes address-pool=DMZ interface=VLAN-10 lease-time=10m name=DMZ
add bridge=bridge comment=defconf interface="[2] LAN 1G"
add bridge=BridgeShared comment=defconf frame-types=admit-only-untagged-and-priority-tagged interface="[3] ether3" pvid=10
add bridge=bridge comment=defconf interface="[4] ether4"
add bridge=bridge comment=defconf interface="[5] ether5"
add bridge=bridge comment=defconf interface="[6] ether6"
add bridge=bridge comment=defconf interface="[7] ether7"
add bridge=bridge comment=defconf interface="[8] MGMT"
add bridge=bridge comment=defconf interface="[1] LAN 10G"
/interface bridge vlan
add bridge=BridgeShared tagged=BridgeShared untagged="[3] ether3" vlan-ids=10
add comment=defconf interface="[0] WAN Uplink" list=WAN
add address=10.10.0.1/24 comment=defconf interface=bridge network=10.10.0.0
add address=10.10.10.1/24 interface=VLAN-10 network=10.10.10.0
/ip dhcp-client
add address=10.10.0.0/24 comment=defconf dns-server=10.10.0.1 gateway=10.10.0.1 netmask=24
add address=10.10.10.0/24 dns-server=10.10.10.1 domain=DMZ.apl gateway=10.10.10.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=10.10.0.1 comment=defconf name=router.lan
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=22001
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
