VLAN configuration on CSR
flat network (no vlans) 192.168.120.0/24
Now we need to implement SIP telephony service, but there is requirement - sip traffic must be isolated.
And therefore we need implement VLANs on switches.
I search info on this and find two solutions:
So please help me find solution.
export the config of the CSR
i’am simplified the scheme
изображения
Config CRS112:
[admin@MikroTik] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   192.168.120.202/24 192.168.120.0   ether1-master
[admin@MikroTik] > interface ethernet print
Flags: X - disabled, R - running, S - slave
 #    NAME                                  MTU MAC-ADDRESS       ARP        MASTER-PORT                                SWITCH
 0 R  ether1-master                        1500 6C:3B:6B:62:A8:35 enabled    none                                       switch1
 1  S ether2                               1500 6C:3B:6B:62:A8:36 enabled    ether1-master                              switch1
 2  S ;;; buh pc's
      ether3                               1500 6C:3B:6B:62:A8:37 enabled    ether1-master                              switch1
 3 RS ether4                               1500 6C:3B:6B:62:A8:38 enabled    ether1-master                              switch1
 4 RS ;;; videoserver (dina home)
      ether5                               1500 6C:3B:6B:62:A8:39 enabled    ether1-master                              switch1
 5  S ;;; videoserver (main)
      ether6                               1500 6C:3B:6B:62:A8:3A enabled    ether1-master                              switch1
 6  S ;;; dina pc
      ether7                               1500 6C:3B:6B:62:A8:3B enabled    ether1-master                              switch1
 7 RS ;;; uplink
      ether8                               1500 6C:3B:6B:62:A8:3C enabled    ether1-master                              switch1
 8  S sfp9                                 1500 6C:3B:6B:62:A8:3D enabled    ether1-master                              switch1
 9  S sfp10                                1500 6C:3B:6B:62:A8:3E enabled    ether1-master                              switch1
10  S sfp11                                1500 6C:3B:6B:62:A8:3F enabled    ether1-master                              switch1
11  S sfp12                                1500 6C:3B:6B:62:A8:40 enabled    ether1-master                              switch1
[admin@MikroTik] > interface ethernet switch print
                                                     type: QCA-8511
                                              bridge-type: customer-vid-used-as-lookup-vid
                      drop-if-no-vlan-assignment-on-ports:
  drop-if-invalid-or-src-port-not-member-of-vlan-on-ports: ether1-master,ether4,ether5
                                 unknown-vlan-lookup-mode: svl
                                     forward-unknown-vlan: yes
                          use-svid-in-one2one-vlan-lookup: no
                          use-cvid-in-one2one-vlan-lookup: yes
                                      mac-level-isolation: yes
                                    multicast-lookup-mode: dst-ip-and-vid-for-ipv4
                         override-existing-when-ufdb-full: no
                                      unicast-fdb-timeout: 5m
                                          ingress-mirror0: switch1-cpu,unmodified
                                          ingress-mirror1: switch1-cpu,unmodified
                                     ingress-mirror-ratio: 1/1
                                           egress-mirror0: switch1-cpu,modified
                                           egress-mirror1: switch1-cpu,modified
                                      egress-mirror-ratio: 1/1
                                                 fdb-uses: mirror0
                                                vlan-uses: mirror0
                        mirror-egress-if-ingress-mirrored: no
                                 mirror-tx-on-mirror-port: no
                             mirrored-packet-qos-priority: 0
                          mirrored-packet-drop-precedence: green
                           bypass-vlan-ingress-filter-for:
                         bypass-ingress-port-policing-for:
                      bypass-l2-security-check-filter-for:
[admin@MikroTik] /interface ethernet switch vlan> print
 #   VLAN-ID PORTS                                                  SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
 0 D    4095 switch1-cpu                                            no  no    no    no             none
 1       100 ether1-master                                          no  yes   no    no             none
             ether4
 2       200 ether1-master                                          no  yes   no    no             none
             ether5
[admin@MikroTik] /interface ethernet switch> ingress-vlan-translation print
 0   ports=ether5 service-vlan-format=any customer-vlan-format=any customer-vid=0 new-customer-vid=200 pcp-propagation=no sa-learning=yes
 1   ports=ether4 service-vlan-format=any customer-vlan-format=any customer-vid=0 new-customer-vid=100 pcp-propagation=no sa-learning=yes
 2 D ports="" service-vlan-format=any customer-vlan-format=any new-customer-vid=4095 pcp-propagation=no sa-learning=no
[admin@MikroTik] /interface ethernet switch> egress-vlan-tag print
 #   VLAN-ID TAGGED-PORTS
 0 D    4095
 1       100 ether1-master
 2       200 ether1-master
Config CRS125:
 0   ;;; lan
     192.168.120.203/24 192.168.120.0   ether1-master-local
 0 R  ether1-master-local                  1500 4C:5E:0C:98:B9:BB enabled    none                                       switch1
 1    ;;; internet
      ether2-slave-local                   1500 4C:5E:0C:98:B9:BC enabled    none                                       switch1
 2  S ether3-slave-local                   1500 4C:5E:0C:98:B9:BD enabled    ether1-master-local                        switch1
 3 RS ;;; Storage2
      ether4-slave-local                   1500 4C:5E:0C:98:B9:BE enabled    ether1-master-local                        switch1
 4  S ;;; esx3 iLo
      ether5-slave-local                   1500 4C:5E:0C:98:B9:BF enabled    ether1-master-local                        switch1
 5  S ether6-slave-local                   1500 4C:5E:0C:98:B9:C0 enabled    ether1-master-local                        switch1
 6  S ;;; esx3
      ether7-slave-local                   1500 4C:5E:0C:98:B9:C1 enabled    ether1-master-local                        switch1
 7  S ether8-slave-local                   1500 4C:5E:0C:98:B9:C2 enabled    ether1-master-local                        switch1
 8  S ether9-slave-local                   1500 4C:5E:0C:98:B9:C3 enabled    ether1-master-local                        switch1
 9  S ether10-slave-local                  1500 4C:5E:0C:98:B9:C4 enabled    ether1-master-local                        switch1
10  S ether11-slave-local                  1500 4C:5E:0C:98:B9:C5 enabled    ether1-master-local                        switch1
11 RS ether12-slave-local                  1500 4C:5E:0C:98:B9:C6 enabled    ether1-master-local                        switch1
12  S ether13-slave-local                  1500 4C:5E:0C:98:B9:C7 enabled    ether1-master-local                        switch1
13  S ether14-slave-local                  1500 4C:5E:0C:98:B9:C8 enabled    ether1-master-local                        switch1
14  S ether15-slave-local                  1500 4C:5E:0C:98:B9:C9 enabled    ether1-master-local                        switch1
15  S ether16-slave-local                  1500 4C:5E:0C:98:B9:CA enabled    ether1-master-local                        switch1
16  S ;;; esx2
      ether17-slave-local                  1500 4C:5E:0C:98:B9:CB enabled    ether1-master-local                        switch1
17  S ;;; esx2
      ether18-slave-local                  1500 4C:5E:0C:98:B9:CC enabled    ether1-master-local                        switch1
18  S ;;; esx
      ether19-slave-local                  1500 4C:5E:0C:98:B9:CD enabled    ether1-master-local                        switch1
19  S ;;; esx iLo
      ether20-slave-local                  1500 4C:5E:0C:98:B9:CE enabled    ether1-master-local                        switch1
20  S ether21-slave-local                  1500 4C:5E:0C:98:B9:CF enabled    ether1-master-local                        switch1
21  S ether22-slave-local                  1500 4C:5E:0C:98:B9:D0 enabled    ether1-master-local                        switch1
22  S ;;; c2950
      ether23-slave-local                  1500 4C:5E:0C:98:B9:D1 enabled    ether1-master-local                        switch1
23  S ether24-slave-local                  1500 4C:5E:0C:98:B9:D2 enabled    ether1-master-local                        switch1
24  S sfp1-slave-local                     1500 4C:5E:0C:98:B9:D3 enabled    ether1-master-local                        switch1
[admin@MikroTik] /interface ethernet switch> print
                                                     type: QCA-8513L
  drop-if-invalid-or-src-port-not-member-of-vlan-on-ports: ether1-master-local,ether4-slave-local,ether6-slave-local
                                                 fdb-uses: mirror0
                                                vlan-uses: mirror0
[admin@MikroTik] /interface ethernet switch> vlan print
 0 D    4095 ether2-slave-local                                     no  no    no    no             none
             switch1-cpu
 1       100 ether1-master-local                                    no  yes   no    no             none
             ether4-slave-local
 2       200 ether1-master-local                                    no  yes   no    no             none
             ether6-slave-local
 0   ports=ether6-slave-local service-vlan-format=any customer-vlan-format=any customer-vid=0 new-customer-vid=200 pcp-propagation=no sa-learning=yes
 1   ports=ether4-slave-local service-vlan-format=any customer-vlan-format=any customer-vid=0 new-customer-vid=100 pcp-propagation=no sa-learning=yes
 2 D ports=ether2-slave-local service-vlan-format=any customer-vlan-format=any new-customer-vid=4095 pcp-propagation=no sa-learning=no
 0 D    4095
now vlan’s are isolated (wireshark approved) :
  1. pc1 can ping pc2
  2. pc3 can ping pc4
    but
  3. CRS112 can not ping CRS125
  4. i can’t connect to any switch from 4,5 ports on CRS112
    5.i can’t connect to any switch from 4,6 ports on CRS125
How can i resolve this?
try to remove this here
and what you mean on item 4 and 5 ?
removed ‘drop-if-invalid-or-src-port-not-member-of-vlan-on-ports’ on switches, but this does not help
i can’t connect from vlan100 and vlan200 ports to switches
