VLAN Configuration
I having some difficulty with the VLAN configuration on a RB250GS (sw 1.6). The access points and backhauls support a management VLAN which is configured on VLAN 10. What I need to happen is the traffic ingressing/egressing into Port 1 and Port 2 that have VLAN 10 in the header is left alone and passed as is just like if it were a trunk port. Traffic ingressing into Port 1 and Port 2 that does not have a VLAN tag needs to have VLAN 200 added to the header. Traffic egressing from Port 1 and Port 2 that has VLAN 200 added to the header needs to have VLAN 200 stripped. Port 3 and Port 4 are currently configured as access ports for testing accessibility on each VLAN. Port 5 needs to be a 802.1Q trunk port and pass any VLANs that are in it’s membership table. I’ve been able to set this up using HP ProCurve and EtherWan switches, but haven’t been sucessfull with the MikroTik. My configuration and screenshots are below… any suggestions would be appreciated.
Port 1 → Access Point
Port 2 → Access Point
Port 3 → PC (Test VLAN 10)
Port 4 → PC (Test VLAN 200)
Port 5 → Backhaul
Sadly you can’t do that.
http://forum.mikrotik.com/t/please-do-not-tag-default-vlan-in-add-if-missing-mode/41411/1
According to MT that’s a hardware limitation of the switch chip used inside the product, so there are no workarounds. You cannot mix tagged and untagged VLANs on a trunk (multi VLAN) port if the tagged VLAN is also untagged on any other switch ports.
