VLAN configuration
Hi Guys,
Ive been using Mikrotik Routers for a few years, but never with VLANS, there is so muchconflicting information, and I cannot get this working.
The router is a RB1200 running OS 5.16
The port is linked to a Cisco Switch, with the below config
fa0/13 - VLAN237=10.0.100.5/30. VLAN238=10.0.100.13/30
The port is linked into ether8 on the routerboard
This is the vlan config I have
/interface vlan
add arp=enabled disabled=no interface=“ether8 - CWA - DNZ” l2mtu=1596 mtu=
1500 name=DNZ-VLAN-238 use-service-tag=no vlan-id=238
1500 name=CWA-VLAN-237 use-service-tag=no vlan-id=237
add address=10.0.100.6/30 comment=CWA-VLAN-237 disabled=no interface=
CWA-VLAN-237 network=10.0.100.4
add address=10.0.100.14/30 comment=DNZ-Vlan disabled=no interface=
DNZ-VLAN-238 network=10.0.100.12
The conflicting information I have is in regard to bridging, some places say use a bridge, some say dont use a bridge, and are not clear what LAN port you build the bridge from?
Can someone clarify this so I can get it working
The MT config should work.
As for the bridge/no bridge discussion. If you only need tagged traffic, you don’t need a bridge. If, however, you also need untagged traffic, you will need to use a bridge. Either way, it doesn’t hurt anything to use a bridge. Here’s a config:
add name=bridge8
add interface=ether8 bridge=bridge8
/interface vlan
add vlan-id=237 name=vlan237 interface=bridge8
add vlan-id=237 name=vlan238 interface=bridge8
add …If this still isn’t working, can you post your actual config from the cisco?
show run int fa0/13
show run int vlan237
show run int vlan238
Regarding the bridge question it depends on your needs. What are you trying to accomplish?
http://mikrotikroutersetup.blogspot.com/p/mikrotik-router-pppoe-server_29.html
