VLAN connect to internet
I created VLAN 3 to separate network segment and each VLAN attach to ether3, ether4 and ether5. DHCP is created and assigned to each VLAN. When computer connect to ether3, DHCP will provide the IP address. However, each VLAN can not connect to internet because internet is using ether2 to connect to internet.
Please guide how to allow VLAN to access to internet. Please see my configuration as below:
add name=bridge protocol-mode=none
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
/interface vlan
add interface=bridge name=VLAN1 vlan-id=1
add interface=bridge name=VLAN2 vlan-id=2
add interface=bridge name=VLAN3 vlan-id=3
add address=192.168.2.1/24 interface=VLAN1
add address=192.168.3.1/24 interface=VLAN2
add address=192.168.4.1/24 interface=VLAN3
add name=POOL1 ranges=192.168.2.1-192.168.2.100
add name=POOL2 ranges=192.168.3.1-192.168.3.254
add name=POOL3 ranges=192.168.4.1-192.168.4.254
add address-pool=POOL1 disabled=no interface=VLAN1 name=DHCP1
add address-pool=POOL2 disabled=no interface=VLAN2 name=DHCP2
add address-pool=POOL3 disabled=no interface=VLAN3 name=DHCP3
add address=192.168.2.0/24 dns-server=8.8.8.8 gateway=192.168.2.1
add address=192.168.3.0/24 dns-server=8.8.8.8 gateway=192.168.3.1
add address=192.168.4.0/24 dns-server=8.8.8.8 gateway=192.168.4.1
add action=masquerade chain=srcnat out-interface=ether2
add independent-learning=yes ports=ether3,switch1-cpu switch=switch1 vlan-id=1
add independent-learning=yes ports=ether4,switch1-cpu switch=switch1 vlan-id=2
add independent-learning=yes ports=ether5,switch1-cpu switch=switch1 vlan-id=3
set ether3 default-vlan-id=1 vlan-header=always-strip vlan-mode=secure
set ether4 default-vlan-id=2 vlan-header=always-strip vlan-mode=secure
set ether5 default-vlan-id=3 vlan-header=always-strip vlan-mode=secure
set switch1-cpu vlan-mode=secure
Use of VLAN ID 1 can bring a lot of trouble … it seems that ROS uses that ID implicitly for untagged traffic on bridge and if you try to explicitly tag frames with this VLAN ID, they are still considered untagged…
mkx hit the nail on the head as that is the first thing I noticed.
I also do not understand your ethernet switch (vlan or port) settings.
I have no such think on my hex (or dont use it for my vlans).
I use bridge for vlans and thus use bridge ports to identify ethport interfaces or wlan interfaces.
Vlans are there own interface entity whose parent interface is the bridge. Which you seem to have already done, and thus why I am perplexed.
RBs with decent switch chips (hEX is not one of them) can deal with VLANs in hardware (as it used to be THE way on ROS <6.41). The config section /interface ethernet switch deals with it.
Seems like new hardware, even though it has decent switch chip, will not expose this config interface any more.
Why complicate things with VLAN’s, just create your IPs on each interface
Often one does not have the physical luxury of 3 different ethernet physical connections to support different LANs, hence vlans have an advantage.
I can access to internet after I added ether2 that connected to modem, but it assigned new DHCP IP range. That is not what I want.
I want to keep the same IP address that provided from DHCP of each VLAN.
