I’m quite a beginner with MikroTik and networking in general, so please bear with me ![]()
I’m using a 2011UiAS-2HnD which currently has a config which came from quickset, and I’m trying to rework towards what I want, so there might be a lot of clutter in my current config.
Currently the setup is very simple, WAN is connected to ether10 and set to be DHCP client. All other ports are bridged together and have a DCHP server running which does basic routing, so far so good.
Now I want to connect an AP to one of the ports which will have 2 wlans, one for private use and one for public use. The private one currently is untagged (like the rest of the configuration so far) and the public one I’m trying to put in VLAN1, with the goal that everything connected to the public WLAN is not able to reach anything on the private side.
I’ve added a vlan1 interface, DHCP server and IP pool, but when I connect a device to the public WLAN (vlan1) I’m not getting any IP address, so I’m probably messing up something simple. There is currently some wlan config in the routerboard, but this can be ignored, it will be removed once the external AP’s are working.
Private is 192.168.88.0/24
Public is 192.168.2.0/24
Hope someone can point me into the right direction, tia!
Here is my current config:
# aug/10/2019 17:49:09 by RouterOS 6.45.3
# software id = 3DKL-L98X
# model = 2011UiAS-2HnD
# serial number = 63FA055724F0
add admin-mac=E4:8D:8C:7A:AA:86 auto-mac=no fast-forward=no name=bridge-local
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether7 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether8 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether9 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full comment=AP
set [ find default-name=sfp1 ] disabled=yes
set [ find default-name=ether10 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full comment=wan name=wan poe-out=off
/interface vlan
add interface=wan name=vlan1 vlan-id=1
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed mode=\
dynamic-keys name=normal supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=4 band=2ghz-b/g/n channel-width=\
20/40mhz-Ce country=netherlands disabled=no distance=indoors frequency=\
auto frequency-mode=regulatory-domain mode=ap-bridge security-profile=\
normal ssid=test wireless-protocol=802.11
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.88.20-192.168.88.254
add name=dhcp_pool_vlan1 ranges=192.168.2.20-192.168.2.254
add address-pool=dhcp authoritative=after-2sec-delay disabled=no interface=\
bridge-local name=dhcp
add address-pool=dhcp_pool_vlan1 disabled=no interface=vlan1 name=dhcp_vlan1
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=bridge-local hw=no interface=ether2
add bridge=bridge-local hw=no interface=ether6
add bridge=bridge-local interface=wlan1
add bridge=bridge-local hw=no interface=ether3
add bridge=bridge-local hw=no interface=ether4
add bridge=bridge-local hw=no interface=ether5
add bridge=bridge-local hw=no interface=ether7
add bridge=bridge-local hw=no interface=ether8
add bridge=bridge-local hw=no interface=ether1
add bridge=bridge-local interface=ether9
set discover-interface-list=discover
add interface=sfp1 list=discover
add interface=ether2 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=ether6 list=discover
add interface=ether7 list=discover
add interface=ether8 list=discover
add interface=ether9 list=discover
add interface=wan list=discover
add interface=wlan1 list=discover
add interface=bridge-local list=discover
add interface=ether2 list=mactel
add interface=ether3 list=mactel
add interface=ether2 list=mac-winbox
add interface=ether4 list=mactel
add interface=ether3 list=mac-winbox
add interface=ether5 list=mactel
add interface=ether4 list=mac-winbox
add interface=ether6 list=mactel
add interface=ether5 list=mac-winbox
add interface=ether7 list=mactel
add interface=ether6 list=mac-winbox
add interface=ether8 list=mactel
add interface=ether7 list=mac-winbox
add interface=ether9 list=mactel
add interface=ether8 list=mac-winbox
add interface=wan list=mactel
add interface=ether9 list=mac-winbox
add interface=sfp1 list=mactel
add interface=wlan1 list=mactel
add interface=bridge-local list=mactel
add interface=wan list=mac-winbox
add interface=sfp1 list=mac-winbox
add interface=wlan1 list=mac-winbox
add interface=bridge-local list=mac-winbox
add address=192.168.88.1/24 comment="default configuration" interface=ether2 \
network=192.168.88.0
add address=192.168.2.1/24 interface=vlan1 network=192.168.2.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
no interface=wan
/ip dhcp-server lease
add address=192.168.88.6 client-id=1:d8:d:17:3e:59:9a comment=AP1 \
mac-address=D8:0D:17:3E:59:9A server=dhcp
add address=192.168.2.0/24 gateway=192.168.2.1
add address=192.168.88.0/24 comment="default configuration" gateway=\
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="default configuration" protocol=icmp
add action=accept chain=input comment="default configuration" \
add action=drop chain=input comment="default configuration" in-interface=wan
add action=fasttrack-connection chain=forward comment="default configuration" \
add action=accept chain=forward comment="default configuration" \
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=wan
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=wan
/system clock
set time-zone-name=Europe/Amsterdam
/system logging
add topics=dhcp
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
