Vlan don't go on internet
Hi!
I have a problem.. the vlan 100 who is bonded with JP’s lan does not work on internet.. devices on this network, in 192.168.2.0 network, ping 192.168.2.1 gateway without any issue but can’t go on internet.
Can you help me? I didn’t see what’s the bug
Quick schema: Cell phone on SSID xyz → Ubiquiti SSID xyz on vlan 100 → Netgear managed switch → Mikrotik → Internet PPPoE Bell Fiber
All the link are well connected with vlan 100 tagged. The problem is in the mikrotik, the cell phone ping the gateway.
Thanks!
2024-03-21 15:15:40 by RouterOS 7.14.1
software id = 13S7-4K9N
model = RB5009UG+S+
serial number = HFD095XXXXX
set [ find default-name=ether2 ] name=Dave
set [ find default-name=ether1 ] name=Internet
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=Internet name=“Bell PPPoE” \
password=xxxxx use-peer-dns=yes user=b12xxxxx
/interface vlan
add interface=Dave name=JP vlan-id=100
add interface=Dave name=Security vlan-id=200
add interface=Dave name=Spa vlan-id=400
add interface=Dave name=Visiteurs vlan-id=10
add interface=Dave name=iot vlan-id=300
add name=WAN
add name=LAN
/ip firewall layer7-protocol
add name=“Block YoutubeApp” regexp="^.+(youtube.com|www.youtube.com|m.youtube.\
com|ytimg.com|s.ytimg.com|ytimg.l.google.com|youtube.l.google.com|i.google\
.com|googlevideo.com|youtu.be).*$"
add name=“Block tiktok” regexp="^.+(myqcloud.com|wsdvs.com|worldfcdn.com|footp\
rint.net|byteoversea.|ibyteimg.|.ibyteimg|ibyteimg.com|musemuse.cn|muscdn.\
com|.byteoversea|byted.org|bytecdn.cn|byteoversea.com|.musical|musical.|mu\
sical.ly|tiktokcdn.com|tiktokv.com|tiktokcdn.com|.tiktokv|tiktokv.|tiktokc\
dn-com|.akamaized|akamaized.net|akamaized.|tiktok.com|www.tiktok.com|m.tik\
tok.com|tiktok.|tiktok|.zhiliaoapp|.musically|zhiliaoapp.|musically.).*$"
add name=Facebook regexp="^.+(www.facebook.com|facebook.com|login.facebook.com\
|www.login.facebook.com|fbcdn.net|www.fbcdn.net|fbcdn.com|www.fbcdn.com|st\
atic.ak.fbcdn.net|static.ak.connect.facebook.com|connect.facebook.net|> www> .\
connect.facebook.net|apps.facebook.com).*\$"^.+"
add name=Pool_Dave ranges=192.168.1.100-192.168.1.254
add name=Pool_Security ranges=192.168.200.10-192.168.200.100
add name=Pool_JP ranges=192.168.2.100-192.168.2.200
add name=Pool_iot ranges=192.168.3.10-192.168.3.254
add name=Pool_Visiteurs ranges=10.0.10.100-10.0.10.200
add name=Pool_Spa ranges=192.168.4.100-192.168.4.150
add address-pool=Pool_Dave interface=Dave lease-time=10m name=DHCP_Dave
add address-pool=Pool_Security interface=Security lease-time=10m name=\
DHCP_Security
add address-pool=Pool_JP interface=JP name=DHCP_JP
add address-pool=Pool_iot interface=iot name=DHCP_iot
add address-pool=Pool_Visiteurs interface=Visiteurs name=DHCP_Visiteurs
add address-pool=Pool_Spa interface=Spa name=DHCP_Spa
/ip smb users
/queue simple
add burst-limit=100M/100M burst-threshold=15M/15M burst-time=5s/5s max-limit=\
20M/20M name=QOS_Visiteurs target=Visiteurs
set udp-timeout=10s
/interface detect-internet
set detect-interface-list=all
add interface=“Bell PPPoE” list=WAN
add interface=*FFFFFFFF list=LAN
add address=192.168.1.1/24 interface=Dave network=192.168.1.0
add address=192.168.200.1/24 interface=Security network=192.168.200.0
add address=192.168.2.1/24 interface=JP network=192.168.2.0
add address=192.168.3.1/24 interface=iot network=192.168.3.0
add address=10.0.10.1/24 interface=Visiteurs network=10.0.10.0
add address=192.168.4.1/24 interface=Spa network=192.168.4.0
/ip dhcp-server lease
Removed for visual confort
add address=10.0.10.0/24 dns-server=8.8.8.8 gateway=10.0.10.1
add address=192.168.1.0/24 dns-server=192.168.1.10 gateway=192.168.1.1 \
netmask=24
add address=192.168.2.0/24 dns-server=8.8.8.8 gateway=192.168.2.1
add address=192.168.3.0/24 dns-server=8.8.8.8 gateway=192.168.3.1
add address=192.168.4.0/24 dns-server=8.8.8.8 gateway=192.168.4.1 netmask=24
add address=192.168.200.0/24 dns-none=yes gateway=192.168.200.1
/ip firewall address-list
Removed a lot for visual confort
add address=192.168.1.0/24 list=Block_Visiteurs
add address=192.168.2.0/24 list=Block_Visiteurs
add address=192.168.3.0/24 list=Block_Visiteurs
add address=192.168.200.0/24 list=Block_Visiteurs
add action=drop chain=input comment=“Block China” in-interface=“Bell PPPoE” \
src-address-list=CN
add action=drop chain=input comment=“Block Russia” in-interface=“Bell PPPoE” \
src-address-list=RU
add action=drop chain=forward comment=“Block internet security” \
out-interface=“Bell PPPoE” src-address-list=Security
“Allow Winbox attempt from internet CANADA ONLY” dst-port=8291 \
in-interface=“Bell PPPoE” log-prefix=winboxWAN protocol=tcp \
src-address-list=!CA
add action=drop chain=input comment=“Drop ping from WAN” disabled=yes \
in-interface=“Bell PPPoE” protocol=icmp
add action=accept chain=forward comment=“Accept JP->DNS Dave” dst-address=\
192.168.1.10 dst-port=53 protocol=udp src-address=192.168.2.0/24
add action=drop chain=forward comment=“Block JP->Dave” dst-address=\
192.168.1.0/24 src-address=192.168.2.0/24
add action=drop chain=forward comment=“Block JP->Security” dst-address=\
192.168.200.0/24 src-address=192.168.2.0/24
add action=drop chain=forward comment=“Block Visteurs->Tous” \
dst-address-list=Block_Visiteurs src-address=10.0.10.0/24
add action=masquerade chain=srcnat out-interface=“Bell PPPoE” src-address=\
192.168.1.0/24
192.168.2.0/24
192.168.3.0/24
10.0.10.0/24
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set sip disabled=yes
/ip service
set telnet disabled=yes
set www address=192.168.1.0/24
set ssh address=192.168.1.0/24
set api disabled=yes
set api-ssl disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 firewall address-list
/system clock
set time-zone-name=America/Toronto
/system note
set show-at-login=no
/system script
/tool bandwidth-server
set authenticate=no enabled=no
Without checking the config…did you add the VLAN to LAN in the /interface list member?
nope.. it's the only vlan who can't connect to internet, all others are OK
Added, no difference..
Try to change this:
add action=masquerade chain=srcnat out-interface="Bell PPPoE" src-address=192.168.1.0/24
add action=masquerade chain=srcnat out-interface="Bell PPPoE" src-address=192.168.2.0/24
add action=masquerade chain=srcnat out-interface="Bell PPPoE" src-address=192.168.3.0/24
add action=masquerade chain=srcnat out-interface="Bell PPPoE" src-address=10.0.10.0/24
to this:
Did not work.. again, all vlan go to the internet, no this vlan especially
Well you have this rule in the middle of your IP firewall filter:
/interface vlan
add action=drop chain=forward comment="Block internet security" \
    out-interface="Bell PPPoE" src-address-list=Security
You’ve omitted most of the address list entries from the export output, but I assume that that “Security” list has the address ranges of VLAN 200, the “Security” VLAN (192.168.200.10-192.168.200.100)?
Correct, security is my ip camera.. I don’t want them to talk with china :stuck_out_tongue: hehehe yes it’s 192.168.200.0/24
the vlan who don’t wanna go on the internet is 192.168.2.0/24
Yes, but above you’ve described connection problems with vlan 200. And the vlan with that id is the “Security” one with the 192.168.200.10-192.168.200.100 range. So according to your configuration. It’s normal that that vlan 200 is unable to go to the internet.
Your “JP” vlan is the one with id=100. Shouldn’t you configure your device to use that vlan 100 instead to be able to go to the internet?
My bad.. vlan 100 can’t go on the internet. Just edited original post
Does ping 1.1.1.1 work from a device using vlan 100? Also do the devices in vlan 100 use 8.8.8.8 as DNS server or 192.168.1.10? If they use 192.168.1.10 you might need another “Accept JP->DNS Dave” rule, but this time for protocol=tcp dst-port=53. If the DNS query answers are bigger than the limit of one UDP packet, the query will switch to using TCP 53 instead of UDP 53.
Besides that, your current firewall configuration is not secure. You are missing drop all rules for both the input and forward chains (see https://help.mikrotik.com/docs/display/ROS/Building+Advanced+Firewall). On your RB5009, you can see the firewall rules shipped with the default configuration by executing the command:
/system/default-configuration/print without-paging
and finding the section that begins with /interface list member add list=LAN interface=bridge comment=“defconf”. If you use the rules from the web page above or defconf, you’ll need to add all your vlan interfaces to the list LAN and remove the existing invalid entry *FFFFFFF which was for the bridge that you’ve removed. You’ll also see that the masquerade rule for instance uses the better practice of using interface list (WAN) instead of specifying the individual interface (“Bell PPPoE”) and that ICMP should not be blocked on the input chain! ICMP is not only used for ping but also for important stuffs like path MTU discovery. If you want to drop ping, filter only echo request by adding the condition icmp-options=0:0-255 to the drop rule.
