I tried with ROS 7.7 to create multiple SSIDs, separated with VLANs as decribed here:
https://wiki.mikrotik.com/wiki/Manual:VLANs_on_Wireless
Here is stated:
Note: It is important to set wlan1,wlan2 vlan-mode to “use-tag”.
And:
add fast-forward=no name=bridge1 vlan-filtering=yes
But exactly THIS does NOT work!
vlan-filtering=yes + use-tag → no connection
vlan-filtering=no + use-tag → connection
vlan-filtering=yes + no-tag → connection
If you choose “vlan-filtering=yes + no-tag” it is needed to set the correct PVID on the VLAN-Ports too!
Can someone explain this and why it is described that way in the wiki?
