I have four switches: 2x CRS328-24P-4S+ as EDGE switches and 2x CRS317-1G-16S+ as CORE switches. On all switches I have only one bridge for HW Offloading. There is also enabled on Bridge VLAN Filtering and Ingress Filtering on all switches and the MSTP is set. Master bridge has 1st CRS328-24P-4S+.
Network topology is like that:
1st CRS328-24P-4S+ is connected with sfp+1 to 1st CRS317-1G-16S+ and with sfp+2 to 2nd CRS317-1G-16S+.
2nd CRS328-24P-4S+ is connected with sfp+1 to 2st CRS317-1G-16S+ and with sfp+2 to 1nd CRS317-1G-16S+.
1st CRS317-1G-16S+ and 2nd CRS317-1G-16S+ have bonded port each other.
The problem is that I see ARP requests from different VLANs on ALL interfaces and they are not in the same VLAN. For Example if I do TCPDUMP on a port which is only VLAN 2 untagged (my LAN) I see broadcast traffic from VLAN 100 (from my ISP):
15:55:51.195928 ARP, Request who-has cpe-168.static.xxx.net tell ip.ac.xxx.net, length 46
15:55:51.195934 ARP, Request who-has cpe-168.static.xxx.net tell ip.ac.xxx.net, length 46
15:55:51.195938 ARP, Request who-has cpe-213.static.xxx.net tell ip.ac.xxx.net, length 46
15:55:51.195940 ARP, Request who-has cpe-213.static.xxx.net tell ip.ac.xxx.net, length 46
Each of this packets above has in header 4 times VLAN ID 4095 and one VLAN 100.
Does anyone have any idea what would be wrong with the configuration?
