MT1 is the main router
MT2 is more or less a bridge with all his ports
MT3 is a WLAN-AP for my wireless devices.
I now want to use VLANs for building a private WLAN and a separated guest WLAN, which have only access to the INET, not to the rest of my LAN. Some kind of DMZ.
I have no idea to realise this!
I just finished this at home after I got everything worked out with my private WLAN
I didn’t feel like messing with VLANs when I did mine.
setup a new wireless security profile
create a VirtualAP and name it what you want, apply the new security profile.
setup firewall rule in chain forward to block where the dst address is your LAN and the in-interface is your new VirtualAP
(repeat as needed to keep traffic out).
add a new address/network in IP/addresses.
create a pool to use for DHCP in that network
create a DHCP server on your VirtualAP interface and use your guest DHCP pool
while in the DHCP server area, add a network with your address, gateway, and dns servers
make sure in IP/services that you only allow access to your router from what address/networks you need to.
This got my guest network up in pretty short order. But there are probably better/harder ways to do it. But I can’t get to anything I don’t want people to have from the guest wireless. I went a bit further and added a couple mangle rules and branches on my queue tree to give the guests a very limited fraction of my total bandwidth.
Next I’m looking into doing a script to turn off my guest WLAN when my primary and secondary internet links go down before I bring up the USB LTE modem.
I’m also using just one RB951G-2HnD at home, so I don’t know how this will change when dealing with a chain of RB’s
Hotspot for public wifi vlan and seperate vlan for private wifi, which is connected to existing lan bridge at MT1
Example: Vlan 8 public wifi.
MT1:
Create bridge. Add no ports to it yet. Maybe called br-publicwifi. Assign IP.
On interface connected to MT2 - add Vlan 8 and add to br-publicwifi
Create open VirtualAP called e.g. Publicwifi and add to br-publicwifi
Run hotspot setup, but use br-publicwifi as the interface in the wizard.
MT3:
Create bridge br-publicwifi. Do NOT assign IP.
On interface connected to MT2 - add vlan 8 and add to br-publicwifi.
Create virtualap publicwifi and add to br-publicwifi.
No need to configure MT2 as it is bridge.
Example Private VLAN 5;
MT1:
On interface connected to MT2 - add Vlan 5 and add to bridge of LAN.
Create wireless security profile with psk.
Create VirtualAP called e.g. Privatewifi, assign above secuirty profile and add to bridge of LAN
MT3:
Create bridge br-privatewifi. Do NOT assign IP.
On interface connected to MT2 - add vlan 5 and add to br-privatewifi.
Create same wireless security profile as on MT1.
Create virtualap privatewifi, assign above security profile and add to br-privatewifi.
