- Routeros-7.0beta1-arm.npk
- RBD52G-5HacD2HnD-TC
- Has anyone gotten VLAN tags to work on v7?
Yes, hardware VLAN switching works fine between bridged ports, however, tagged management access does not work correctly, should be fixed in further beta versions. Perhaps you managed to find out some other issues? Can you share a configuration export?
It's a VLAN assigned to the bridge interface.
Edited to include config
/interface/bridge> print
0 R name="Bridge_LAN" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=74:4D:28:D5:36:DB
protocol-mode=none fast-forward=yes igmp-snooping=no priority=0x8000 auto-mac=yes max-message-age=20s
forward-delay=15s transmit-hold-count=6 ageing-time=5m region-name="" region-revision=0 max-hops=20
vlan-filtering=no dhcp-snooping=no
/interface/bridge/port> print
Flags: X - disabled, I - inactive; H - hw-offload
Columns: INTERFACE, BRIDGE, HW, Pvid, PRIOrity, PAth-cost, INternal-path-cost, HORIzon
INTERFACE BRIDGE HW P PRIO PA IN HORI
0 H ether1 Bridge_LAN yes 1 0x80 10 10 none
1 H ether4 Bridge_LAN yes 1 0x80 10 10 none
2 IH ether5 Bridge_LAN yes 1 0x80 10 10 none
/interface/vlan> print
Columns: NAME, MTU, ARP, VLan-id, INTERFACE
NAME MTU ARP VL INTERFACE
0 R vlan10 1500 enabled 10 Bridge_LAN
- 6.45.4 → 7.0Beta1
- model = RBD52G-5HacD2HnD
/interface bridge add name=bridge-main
/interface vlan add interface=bridge-main name=VLAN_10 vlan-id=10
set 0 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 1 default-vlan-id=11 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 5 vlan-mode=secure
/interface wireless set [ find default-name=wlan1 ] antenna-gain=3 band=2ghz-g/n bridge-mode=disabled channel-width=20/40mhz-XX country=germany disabled=no frequency-mode=regulatory-domain installation=indoor mode=ap-bridge \
name=WLAN-SSID security-profile=default ssid=WLAN-SSID vlan-id=10 vlan-mode=use-tag wireless-protocol=802.11 wps-mode=disabled
add bridge=bridge-main interface=ether1
add bridge=bridge-main interface=WLAN-SSID
add bridge=bridge-main interface=ether2
add bridge=bridge-main interface=ether3
add bridge=bridge-main interface=ether4
add bridge=bridge-main interface=ether5
add independent-learning=yes ports=switch1-cpu,ether1,ether3,ether4,ether5 switch=switch1 vlan-id=10
add independent-learning=yes ports=switch1-cpu,ether2 switch=switch1 vlan-id=11
/ip address add address=192.168.0.3/24 interface=VLAN_10 network=192.168.0.0
Bugs:
- Management Interface not reachable
- WLAN Clients don’t see the rest of the network (VLAN is not working)
Best Regards
Tobias
I was able to get VLAN’s to work when I assigned the VLAN to a single port and not the bridge.
I noticed that disabling the VLAN before making changes helps.
I had the router lock up on me when making the change.
@Tobei - thank you for sharing, this is the exact issue I was referring on my first post. Will be fixed in further v7 beta versions.
@jrpaz - not sure about your setup, can you share the full export
/export hide-sensitive
How often/fast will 7.0beta versions be released? 1 every week/month?
When setting the VLAN interface to the bridge it doesn’t work.
add name=Bridge_LAN protocol-mode=none
/interface vlan
add comment=vlan10 interface=Bridge_LAN name=vlan10 vlan-id=10
add bridge=Bridge_LAN interface=ether4
add bridge=Bridge_LAN interface=ether5
add bridge=Bridge_LAN interface=wlan1
add bridge=Bridge_LAN interface=wlan2
add bridge=Bridge_LAN interface=ether3
add bridge=Bridge_LAN interface=ether2
However, when I set the VLAN interface to a port on the bridge it works without an issue.
/interface vlan
add comment=vlan10 interface=ether2 name=vlan10 vlan-id=10
In former versions of ROS, bridge should have vlan-filtering=yes set for VLANs to work correctly.
depends on the configuration.
→ https://wiki.mikrotik.com/wiki/Manual:Basic_VLAN_switching
Best Regards
Tobias
