VLAN Help
Have current VLANs 10 & 11 setup. Currently have 2 Tiks using port 24 as trunk to carry both VLANs between these two devices. Now wanting to create another trunk port on Port 23 to carry VLANs from one SXT to another SXT for a P2P connection with another CRS125 on the other end. Port 24 on it will be set as a trunk. I have all the wireless P2P working but can’t figure out how to create a second trunk. Says that VLANs 10 & 11 are already in use.
Thanks!
User ether23 master port as ether24.
Job done.
Are you saying slave port ether23 to master port ether24? I tried that but when I did it that way my other trunk on ether24 to the CRS125 upstairs would lose connection.
Yes.
There should be no reason for you to lose connection elsewhere as you are simply duplicating the port onto another.
