VLAN HW offload
Just try me on a crs226-24g-2s +. I was aware that this is not a rocket, but I currently have fast Ethernet feeling… far away from gigabit. I assume that I have not configured the whole thing correctly. Currently my interfaces look like this:
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 # INTERFACE BRIDGE HW PVID PR PATH-COST INTERNA... HORIZON
 0 vlan10 bridge1 10 0x 10 10 none
 1 vlan20 bridge1 20 0x 10 10 none
 2 vlan1 bridge1 1 0x 10 10 none
 3 vlan30 bridge1 30 0x 10 10 none
 4 I ether2 bridge1 yes 10 0x 10 10 none
 5 I ether3 bridge1 yes 10 0x 10 10 none
 6 I ether4 bridge1 yes 10 0x 10 10 none
 7 I ether5 bridge1 yes 10 0x 10 10 none
 8 I ether6 bridge1 yes 10 0x 10 10 none
 9 I ether8 bridge1 yes 10 0x 10 10 none
10 I ether7 bridge1 yes 10 0x 10 10 none
11 I ether9 bridge1 yes 20 0x 10 10 none
12 I ether10 bridge1 yes 20 0x 10 10 none
13 I ether11 bridge1 yes 20 0x 10 10 none
14 ether12 bridge1 yes 20 0x 10 10 none
15 I ether13 bridge1 yes 20 0x 10 10 none
16 I ether14 bridge1 yes 20 0x 10 10 none
17 I ether15 bridge1 yes 20 0x 10 10 none
18 I ether16 bridge1 yes 20 0x 10 10 none
19 I ether17 bridge1 yes 30 0x 10 10 none
20 I ether18 bridge1 yes 30 0x 10 10 none
21 I ether19 bridge1 yes 30 0x 10 10 none
22 I ether20 bridge1 yes 30 0x 10 10 none
23 I ether21 bridge1 yes 30 0x 10 10 none
24 I ether22 bridge1 yes 30 0x 10 10 none
25 I ether23 bridge1 yes 30 0x 10 10 none
26 I ether24 bridge1 yes 30 0x 10 10 none
Even if HW yes stands it does not seem to run over the separate switch chip and overwhelms the CPU. Is there any idea how I can get the whole more effective? Otherwise everything works so far, DHCP does what it is supposed to. Thank you very much!
Here my config:
# jun/30/2018 23:14:40 by RouterOS 6.42.4
# software id = XXXXX
# model = CRS226-24G-2S+
# serial number = XXXXXXXXX
add fast-forward=no name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan1 vlan-id=1
add interface=bridge1 name=vlan10 vlan-id=10
add interface=bridge1 name=vlan20 vlan-id=20
add interface=bridge1 name=vlan30 vlan-id=30
add name=pool10 ranges=192.168.10.100-192.168.10.200
add name=pool20 ranges=192.168.20.100-192.168.20.200
add name=pool30 ranges=192.168.30.100-192.168.30.200
add address-pool=pool10 disabled=no interface=vlan10 lease-time=3d10m name=\
    server10
add address-pool=pool20 disabled=no interface=vlan20 lease-time=3d10m name=\
    server20
add address-pool=pool30 disabled=no interface=vlan30 lease-time=3d10m name=\
    server30
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
    interface=vlan10 pvid=10
    interface=vlan20 pvid=20
add bridge=bridge1 interface=vlan1
    interface=vlan30 pvid=30
    interface=ether2 pvid=10
    interface=ether3 pvid=10
    interface=ether4 pvid=10
    interface=ether5 pvid=10
    interface=ether6 pvid=10
    interface=ether8 pvid=10
    interface=ether7 pvid=10
    interface=ether9 pvid=20
    interface=ether10 pvid=20
    interface=ether11 pvid=20
    interface=ether12 pvid=20
    interface=ether13 pvid=20
    interface=ether14 pvid=20
    interface=ether15 pvid=20
    interface=ether16 pvid=20
    interface=ether17 pvid=30
    interface=ether18 pvid=30
    interface=ether19 pvid=30
    interface=ether20 pvid=30
    interface=ether21 pvid=30
    interface=ether22 pvid=30
    interface=ether23 pvid=30
    interface=ether24 pvid=30
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,vlan1 vlan-ids=1
add bridge=bridge1 tagged=bridge1,vlan10 untagged=\
    ether2,ether3,ether4,ether5,ether6,ether7,ether8 vlan-ids=10
add bridge=bridge1 tagged=vlan20,bridge1 untagged=\
    ether9,ether10,ether11,ether12,ether13,ether14,ether15,ether16 vlan-ids=20
add bridge=bridge1 tagged=bridge1,vlan30 untagged=\
    ether17,ether18,ether19,ether20,ether21,ether22,ether23,ether24 vlan-ids=30
add address=192.168.50.254/24 interface=ether1 network=192.168.50.0
add address=192.168.1.254/24 interface=vlan1 network=192.168.1.0
add address=192.168.10.254/24 interface=vlan10 network=192.168.10.0
add address=192.168.20.254/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.254/24 interface=vlan30 network=192.168.30.0
add address=192.168.10.0/24 dns-server=192.168.50.1,8.8.8.8 gateway=\
    192.168.10.254 netmask=24
add address=192.168.20.0/24 dns-server=192.168.50.1,8.8.8.8 gateway=\
    192.168.20.254 netmask=24
add address=192.168.30.0/24 dns-server=192.168.50.1,8.8.8.8 gateway=\
    192.168.30.254 netmask=24
add distance=1 gateway=192.168.50.1
/system clock
/system routerboard settings
set silent-boot=no
Looks to me like you have VLAN Filtering turned on.
Based on this https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features turning on VLAN filtering on a CRS2XX turns off HW offload
This filtering would need to go through the very underpowered CPU. CRS226 are great at switching but anything through CPU is painful. I am just beginning swapping all of ours for CRS326 due to the poor performances.
CRS 226 is the most versatile and powerfull switch MIkrotik have
but
hard to configure
only use bridge menu to group ports for switching
you have to configure VLans by the Switch menu to get full wire-speed (thats the objective with a switch)
use this guide
https://wiki.mikrotik.com/wiki/Manual:CRS1xx/2xx_series_switches#VLAN
if you confugure VLans by bridge menu, you will have a very slow 26 port, single core software bridge/router
