I’ve mantbox 15s as AP. I’ve available trunk port Suppose 100, 200, 300. I want to pass trunk port from the AP. And on the client place I’ll install CPE like Sxt Lite5 /LHG 5 etc. I want to use untag port there.
Suppose
Client A = VLan 100
Client B = VLan 200
Client C = VLan 300
and so on…
If I understand it , then you have a Mantbox as AP , connected via a VLAN trunk with VLAN 100,200,300,…
You have several wifi connected CPE/client who should receive/connect just 1 VLAN. (One VLAN per client)
Problem is how do you know what VLAN goes to what CPE station ?
If you specify nothing … and use AP bridge / station bridge …then all tagged VLAN will be transmitted as tagged, but there will be no VLAN filtering in the AP.
The CPE will have to tag/untag the intended VLAN. (This is not done in the WLAN setting, but in the bridge VLAN setting.)
But this is probably not the scenario you want. Every CPE can use any VLAN.
If you want to control the VLAN to which each client connects at the AP side, you might need a virtual WLAN and SSID per client. Then you tag/untag at the AP.
