For various reasons I can currently not upgrade so I am stuck to older RoS versions, pre 6.39.
The scenario is very simple, 4 gigabit ethernet trunklines attached to one CCR who is in the middle so to say, a kind of star.
I want to have the CCR being able to pass traffic between the attached switches trunks , no routing.
Sorry, I dont recommend staying on old firmware nor am aware of old ways of doing switches as I am only capable of grasping and barely at that, the single new way of doing it.
This looks like a case for straightforward port vlan, no 802.1q required.
One possibility, though most probably not optimal, would be to create vlan interfaces on top of all involved ether interfaces and bridge vlans together. Something like this:
/interface vlan
add interface=ether5 name=e5v100 vlan-id=100
add interface=ether5 name=e5v131 vlan-id=131
add interface=ether6 name=e6v100 vlan-id=100
add interface=ether6 name=e6v215 vlan-id=215
add interface=ether6 name=e6v314 vlan-id=314
add interface=ether7 name=e7v100 vlan-id=100
add interface=ether7 name=e7v314 vlan-id=314
#... and so on for all ports/VLANs combination
add name=bridge100
add name=bridge131
add name=bridge215
add name=bridge314
# and so on, one bridge per VLAN
add bridge=bridge100 port=e5v100
add bridge=bridge100 port=e6v100
add bridge=bridge100 port=e7v100
add bridge=bridge131 port=e5v131
add bridge=bridge215 port=e6v215
add bridge=bridge314 port=e6v314
add bridge=bridge314 port=e7v314
# ... and so on for all combinations of VLANs and ports
If later need arises to route traffic, you can simply add IP addresses to bridges of corresponding VLANs and set proper firewall filters…
Yes agree, it is not optimal but works till we can upgrade or replace the CCR with a switch instead, thinking about CRS305-1G-4S+IN for that.
Again thanks!
I have not yet tested the bridge only configuration but will soon do, I am pretty sure it will work.
But if I then later upgrade the CCR to post 6.41(removing the bridge only configuration first), to achieve the same as above but instead using the integrated CCR switch chip, would the configuration be like the below ?
set ether1 vlan-mode=secure vlan-header=add-if-missing
set ether2 vlan-mode=secure vlan-header=add-if-missing
set ether3 vlan-mode=secure vlan-header=add-if-missing
set ether4 vlan-mode=secure vlan-header=add-if-missing
set switch1-cpu vlan-header=leave-as-is vlan-mode=secure
I spotted an error myself, it should not be ether1, ether2, ether4 and ether4 in the example, it should off course be ether5, ether6 and ether7
Wrong:
Correct:
set ether5 vlan-mode=secure vlan-header=add-if-missing
set ether6 vlan-mode=secure vlan-header=add-if-missing
set ether7 vlan-mode=secure vlan-header=add-if-missing
It seems fine to me. But as I don’t have any CCR I xan’t vouch ut will work … many Routerboard devices have their own peculiarities in configuration. Your lab tests will show
The lab test show that it is working with one hint.
The hint is, the lab setup did have other ethernet ports, ether1 though ether4 and some other vlans and ip addresses, otherwise the lab setup was exactly as above.
The device used was CCR1009 which has a builtin switch chip that is configurable for ether1->ether4.
Another observation was that we could migrate another in production CCR1009.
We did all steps down to “/interface vlan” as described above.
The migration was simply using set and switch from ether3 to bridge1, e.g. moving the vlans to the bridge.
It actually worked without interruptions and any further configuration.
The migration step become:
/interface vlan
set interface=bridge1 vlan-id=131 name=MGMT
