Hey All,
I have been looking at this for a while and cant seem to make it work.
version: v6.35rc48
model: RB1100AHx2
Trying to run ARP (and DHCP) on a vlan interface and also have it hand out addresses on the layer 2 bridge. If I have vlan 10 tagged traffic come in ARP / DHCP works as expected if I have the DHCP attached to the vlan interface. However ARP / DHCP does not work for the physical interface that I have also added to the bridge (ether5).
If I swap around the IP address to be attached to the bridge then I get the reverse situation, No ARP / DHCP for tagged traffic coming into the router but working for the physical port.
We really need both situations to work if possible.
The config shown is for the first situation, ie. IP address attached to the vlan interface.
[admin@MikroTik] > /interface bridge print
0 R name="CCTV-bridge" mtu=auto actual-mtu=1500 l2mtu=1600 arp=enabled mac-address=E4:8D:8C:1F:0A:4C protocol-mode=rstp
priority=0 auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6
ageing-time=5m
1 R name="lan-bridge" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled mac-address=E4:8D:8C:1F:0A:4B protocol-mode=rstp
ageing-time=5m
2 R name="vlan-10-bridge" mtu=auto actual-mtu=1500 l2mtu=1594 arp=enabled mac-address=E4:8D:8C:1F:0A:4B protocol-mode=rstp
ageing-time=5m
[admin@MikroTik] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 ether2 lan-bridge 0x80 10 none
1 ether3 lan-bridge 0x80 10 none
2 I ether4 lan-bridge 0x80 10 none
3 I ether7 lan-bridge 0x80 10 none
4 I ether8 lan-bridge 0x80 10 none
5 ether9 lan-bridge 0x80 10 none
6 ether10 lan-bridge 0x80 10 none
7 I ether11 CCTV-bridge 0x80 10 none
8 ether12 CCTV-bridge 0x80 10 none
9 ether2-vlan-10 vlan-10-bridge 0x80 10 none
10 vlan-10-int vlan-10-bridge 0x80 10 none
11 ether9-vlan-10 vlan-10-bridge 0x80 10 none
12 ether10-vlan-10 vlan-10-bridge 0x80 10 none
13 ether5 vlan-10-bridge 0x80 10 none
14 I ether6 vlan-10-bridge 0x80 10 none
[admin@MikroTik] > /interface vlan print
Flags: X - disabled, R - running, S - slave
# NAME MTU ARP VLAN-ID INTERFACE
0 R ether2-vlan-10 1500 enabled 10 ether2
1 R ether9-vlan-10 1500 enabled 10 ether9
2 R ether10-vlan-10 1500 enabled 10 ether10
3 R vlan-10-int 1500 enabled 10 vlan-10-bridge
[admin@MikroTik] > /interface print
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R WAN ether 1500 1598 9498 E4:8D:8C:1F:0A:42
1 RS ether2 ether 1500 1598 9498 E4:8D:8C:1F:0A:43
2 RS ether3 ether 1500 1598 9498 E4:8D:8C:1F:0A:44
3 S ether4 ether 1500 1598 9498 E4:8D:8C:1F:0A:45
4 RS ether5 ether 1500 1598 9498 E4:8D:8C:1F:0A:46
5 S ether6 ether 1500 1598 9498 E4:8D:8C:1F:0A:47
6 S ether7 ether 1500 1598 9498 E4:8D:8C:1F:0A:48
7 S ether8 ether 1500 1598 9498 E4:8D:8C:1F:0A:49
8 RS ether9 ether 1500 1598 9498 E4:8D:8C:1F:0A:4A
9 RS ether10 ether 1500 1598 9498 E4:8D:8C:1F:0A:4B
10 S ether11 ether 1500 1600 9500 E4:8D:8C:1F:0A:4C
11 RS ether12 ether 1500 1600 9116 E4:8D:8C:1F:0A:4D
12 ether13 ether 1500 1600 9116 E4:8D:8C:1F:0A:4E
13 R CCTV-bridge bridge 1500 1600 E4:8D:8C:1F:0A:4C
14 RS ether2-vlan-10 vlan 1500 1594 E4:8D:8C:1F:0A:43
15 RS ether9-vlan-10 vlan 1500 1594 E4:8D:8C:1F:0A:4A
16 RS ether10-vlan-10 vlan 1500 1594 E4:8D:8C:1F:0A:4B
17 R lan-bridge bridge 1500 1598 E4:8D:8C:1F:0A:4B
18 R pppoe-wan pppoe-out 1480
19 R vlan-10-bridge bridge 1500 1594 E4:8D:8C:1F:0A:4B
20 R vlan-10-int vlan 1500 1590 E4:8D:8C:1F:0A:4B
[admin@MikroTik] > /ip dhcp-server print
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 lan-dhcp lan-bridge wifi-pool 8h yes
1 staff-dhcp vlan-10-int staff-wifi-pool 10m yes
[admin@MikroTik] > /ip address print
# ADDRESS NETWORK INTERFACE
0 10.0.0.1/16 10.0.0.0 ether2
1 192.168.1.1/24 192.168.1.0 CCTV-bridge
2 192.168.10.1/24 192.168.10.0 vlan-10-int
3 D xx.xx.xx.xx/32 10.20.22.121 pppoe-wan
When I torch on ether5, i see tagged traffic for ARP to destination 0.0.0.0. Makes me think a tag is not being dropped somewhere on egress.
Any help would be greatly appreciated.
