I am brand new on Mikrotik and have my first question. I am owning a hEX Router (RB750Gr3)
I created a Vlan Interface (Vlan2) on the master port (eth3) and Vlan1 is untagged and Vlan2 tagged on eth3.
This works fine but, I want to use slave port eth4 as an access port for Vlan2 but this is not working.
it seems eth4 is working as access port for Vlan1. Can somebody check my config
/interface vlan
add interface=eth3-m-EG name=vlan2 vlan-id=2
set 3 default-vlan-id=2
add independent-learning=yes ports=switch1-cpu,eth3-m-EG switch=switch1 vlan-id=2
[admin@MikroTik] > interface ethernet switch port pr
Flags: I - invalid
# NAME SWITCH VLAN-MODE VLAN-HEADER DEFAULT-VLAN-ID
0 eth1-A1 switch1 fallback 1
1 eth2-TMA switch1 fallback 1
2 eth3-m-EG switch1 fallback 1
3 eth4-cam switch1 fallback 2
4 eth5-switch switch1 fallback 1
5 switch1-cpu switch1 fallback 1
