Vlan Issue
Hey Friends
Am New To vilans
i have creates a Vlan with an id 170 and i want to add the access point at a site witch is like this
RB 1100 —> RB SXT Lite5 ---->SXT Lite 5 (Cpe) then Omnitik as a switch to SXT Lte 5(AP) —> SXT Lite 5 (CPE) Then Omnitik ----> SXT (CPE) Connected To this Omnitik — Mikrotik Metal 2shpn
i want to Add Metal Wlan To Vlan So Some porpuse i tried to add Vlan id = 170 at metal .
add the Vlan 170 at RB 1100 to bridge
it doesnot work .
can Some Buddy help .
Best regards
If all your wireless links are on bridge mode, adding the vlans appriopriately at the end points should work.
Hello . Thank you for reply .
All of my network are bridged
Also 5 ghz links are bridge -station bridge
Ap bridge -staion bridge .
Can you explain more .
Thank you
I guess your reason for doing VLAN is to logically separate the traffic to some end users/terminal points. So, at one end you have several VLANs (trunk) and at the terminal points you have the individual VLANs (access). If you tag the interface at one end, the bridge propagates your traffic as tagged packets to the remote end of the bridge where you can untag it by creating an access port on the device or deliver it as a tagged traffic to your end user device, if they are expecting tagged traffic from your network.
yes this is why
i want seperate customers
can you please give me links so i can get a clear idea on how can i accomplish this
best regards
Check this page: http://wiki.mikrotik.com/wiki/Vlans_on_Mikrotik_environment
It will give you a clue on how to go about it.
Thank you very much
i really appreicate this
