Hi Guys
Have been having an issue getting my vlanning going.
I have always struggled with VLANs on Mik and I cannot really tell you why.
Anyway I am looking at using this separate VLAN for a DMZ.
From my Cisco I have configured a switchport trunk with the required VLAN allowed and then the VLAN on my VM.
If I put an IP on the VLAN on my Mikrotik which is connected to my Cisco, I can ping it from the VM.
The issue is that when I try and turn the another port into an access port which will then lead to a break out it breaks.
Basically what I am trying to achieve is the following.
I have a /29 that is accessible on our provider edge, I have configured Eth1 with the first IP and pointed the default IP at the gateway from the provider, all working and I have internet access.
What I then have is one cable going to the second port of my provider edge, which has access to the /29 gateway on the edge, and then another link going ot the Cisco.
What I want to do is have the port from the provider edge untagged on my VLAN and then Tagged on the port that goes to the Cisco.
I have read all the guides and feel like a bit of a spesh because I don’t seem to be understanding something.
Any help would be appreciated.
