VLAN MANAGEMENT IP Problem For ACCESS/CPE Antenna
How to make a good connection in VLAN function.
Before i use a ordinary switch all VLAN 100 for MANAGEMENT ACCESS - Antenna/CPE are working.
After i use a CRS328-24P-4S+, dhcp was working but in VLAN DHCP was offered dhcp was showing
/interface bridge filter
add action=accept chain=forward comment="BLOCK ROGUE" dst-port=67 \
    ip-protocol=udp mac-protocol=ip out-interface=ether23 src-port=68
add action=drop chain=forward dst-port=67 ip-protocol=udp mac-protocol=ip \
    src-port=68
add bridge=bridge-network interface=ether1
add bridge=bridge-network interface=ether2
add bridge=bridge-network interface=ether3
add bridge=bridge-network interface=ether4
add bridge=bridge-network interface=ether5
add bridge=bridge-network interface=ether6
add bridge=bridge-network interface=ether7
add bridge=bridge-network interface=ether8
add bridge=bridge-network interface=ether9
add bridge=bridge-network interface=ether10
add bridge=bridge-network interface=ether11
add bridge=bridge-network interface=ether12
add bridge=bridge-network interface=ether13
add bridge=bridge-network interface=ether14
add bridge=bridge-network interface=ether15
add bridge=bridge-network interface=ether16
add bridge=bridge-network interface=ether17
add bridge=bridge-network interface=ether18
add bridge=bridge-network interface=ether19
add bridge=bridge-network interface=ether20
add bridge=bridge-network interface=ether21
add bridge=bridge-network interface=ether22
add bridge=bridge-network interface=ether23 trusted=yes
add bridge=bridge-network interface=ether24
add bridge=bridge-network interface=sfp-sfpplus1
add bridge=bridge-network interface=sfp-sfpplus2
add bridge=bridge-network interface=sfp-sfpplus3
add bridge=bridge-network interface=sfp-sfpplus4
/interface bridge vlan
add bridge=bridge-network untagged="ether2,ether3,ether4,ether6,ether8,ether9,\
    ether11,ether12,ether18,ether21,ether22,ether24" vlan-ids=100
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=ether9 list=LAN
add interface=ether10 list=LAN
add interface=ether11 list=LAN
add interface=ether12 list=LAN
add interface=ether13 list=LAN
add interface=ether14 list=LAN
add interface=ether15 list=LAN
add interface=ether16 list=LAN
add interface=ether17 list=LAN
add interface=ether18 list=LAN
add interface=ether19 list=LAN
add interface=ether20 list=LAN
add interface=ether21 list=LAN
add interface=ether22 list=LAN
add interface=ether24 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
add interface=ether1 list=WAN
add interface=ether23 list=LAN
