vlan managemet forwardin CRS3XX
hi
i have two crs326 switch i defiend vlan management 99 on both switches with different ip address.
i bonded two switch with sfp and bonded 3 eth port connected to proxmox.
i installed a OS on proxmox and set vlan tag 99 on its interface.
i need to manage both switches with this os.
for test i added another vlan 99 to servers bond on one switch .
i can see vlan 99 on bonded server but i cant see vlan 99 interface on bridge of both switches. one switch is only for clients and second for clinets and servers and other equipments
clients switch
[admin@mikrotik_cli] > export
jan/02/1970 01:18:19 by RouterOS 6.42.7
software id = EZD3-1T61
model = CRS326-24G-2S+
serial number = 763C07AE3053
add admin-mac=64:D1:54:DE:29:60 auto-mac=no comment=defconf name=bridge
vlan-filtering=yes
set [ find default-name=sfp-sfpplus2 ] mac-address=64:D1:54:DE:29:78
/interface vlan
add interface=bridge name=mgm vlan-id=99
/interface bonding
add mode=802.3ad name=bonding_sfp slaves=sfp-sfpplus1,sfp-sfpplus2
transmit-hash-policy=layer-2-and-3
/interface vlan
add interface=bonding_sfp name=vlan_mng vlan-id=99
/ip hotspot profile
add bridge=bridge comment=defconf ingress-filtering=yes interface=ether1
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged
ingress-filtering=yes interface=ether2 pvid=10
ingress-filtering=yes interface=ether3 pvid=10
ingress-filtering=yes interface=ether4 pvid=10
ingress-filtering=yes interface=ether5 pvid=10
ingress-filtering=yes interface=ether6 pvid=10
ingress-filtering=yes interface=ether7 pvid=10
ingress-filtering=yes interface=ether8 pvid=10
ingress-filtering=yes interface=ether9 pvid=10
ingress-filtering=yes interface=ether10 pvid=10
ingress-filtering=yes interface=ether11 pvid=10
ingress-filtering=yes interface=ether12 pvid=10
ingress-filtering=yes interface=ether13 pvid=10
ingress-filtering=yes interface=ether14 pvid=10
ingress-filtering=yes interface=ether15 pvid=10
ingress-filtering=yes interface=ether16 pvid=10
ingress-filtering=yes interface=ether17 pvid=10
ingress-filtering=yes interface=ether18 pvid=10
ingress-filtering=yes interface=ether19 pvid=10
ingress-filtering=yes interface=ether20 pvid=10
ingress-filtering=yes interface=ether21 pvid=10
ingress-filtering=yes interface=ether22 pvid=10
ingress-filtering=yes interface=ether23 pvid=10
ingress-filtering=yes interface=ether24 pvid=10
add bridge=bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes
/interface bridge vlan
add bridge=bridge tagged=bonding_sfp untagged="ether1,ether2,ether3,ether4,ether
5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,ether1
5,ether16,ether17,ether18,ether19,ether20,ether21,ether22,ether23,ether24"
vlan-ids=10
add bridge=bridge tagged=bridge,bonding_sfp,ether1 untagged=ether2 vlan-ids=99
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=192.168.99.3/24 interface=mgm network=192.168.99.0
add address=192.168.99.33 interface=vlan_mng network=192.168.99.33
set servers=192.168.30.20
add distance=1 gateway=192.168.99.1
/system identity
set name=mikrotik_client
/system routerboard settings
set boot-os=router-os silent-boot=no
servers switch
[admin@MikroTik_srvs] > /export
compact file hide-sensitive terse verbose
jan/02/1970 01:12:06 by RouterOS 6.42.7
software id = 2EGQ-MPSI
serial number = 763C0982CA2F
add admin-mac=64:D1:54:DE:1D:7E auto-mac=no comment=defconf name=bridge
vlan-filtering=yes
set [ find default-name=ether8 ] mac-address=64:D1:54:DE:2D:54
set [ find default-name=ether9 ] mac-address=64:D1:54:DE:2D:54
set [ find default-name=sfp-sfpplus2 ] mac-address=64:D1:54:DE:2D:93
/interface vlan
/interface bonding
add mode=802.3ad name=bonding_srv slaves=ether7,ether8,ether9
/interface vlan
add interface=bonding_srv name=vlan_mng vlan-id=99
/ip hotspot profile
add bridge=bridge comment=defconf frame-types=
admit-only-untagged-and-priority-tagged interface=ether1
admit-only-untagged-and-priority-tagged interface=ether3 pvid=30
admit-only-untagged-and-priority-tagged interface=ether4 pvid=30
admit-only-untagged-and-priority-tagged interface=ether5 pvid=30
admit-only-untagged-and-priority-tagged interface=ether10 pvid=20
admit-only-untagged-and-priority-tagged interface=ether11 pvid=20
admit-only-untagged-and-priority-tagged interface=ether12 pvid=10
admit-only-untagged-and-priority-tagged interface=ether13 pvid=10
admit-only-untagged-and-priority-tagged interface=ether14 pvid=10
admit-only-untagged-and-priority-tagged interface=ether15 pvid=10
admit-only-untagged-and-priority-tagged interface=ether16 pvid=10
admit-only-untagged-and-priority-tagged interface=ether17 pvid=10
admit-only-untagged-and-priority-tagged interface=ether18 pvid=10
admit-only-untagged-and-priority-tagged interface=ether19 pvid=10
admit-only-untagged-and-priority-tagged interface=ether20 pvid=10
admit-only-untagged-and-priority-tagged interface=ether21 pvid=10
admit-only-untagged-and-priority-tagged interface=ether22 pvid=10
admit-only-untagged-and-priority-tagged interface=ether23 pvid=10
admit-only-untagged-and-priority-tagged interface=ether24 pvid=10
interface=ether2 pvid=30
add bridge=bridge frame-types=admit-only-vlan-tagged interface=bonding_sfp
add bridge=bridge frame-types=admit-only-vlan-tagged interface=bonding_srv
add bridge=bridge interface=ether6
add bridge=bridge tagged=bonding_sfp,bonding_srv untagged="ether12,ether13,ether
14,ether15,ether16,ether17,ether18,ether19,ether20,ether21,ether22,ether23,e
ther24" vlan-ids=10
add bridge=bridge tagged=bonding_srv untagged=
ether2,ether3,ether4,ether5,ether6 vlan-ids=30
add bridge=bridge tagged=bonding_srv,ether6 vlan-ids=20
add bridge=bridge tagged=bonding_srv,ether6,ether11 vlan-ids=21
add bridge=bridge tagged=bonding_srv,bonding_sfp untagged=ether1 vlan-ids=99
add address=192.168.88.2/24 comment=defconf interface=bridge network=
192.168.88.0
add address=192.168.99.20/24 interface=mgm network=192.168.99.0
add address=192.168.88.56/24 interface=bonding_srv network=192.168.88.0
add address=192.168.99.21/24 interface=vlan_mng network=192.168.99.0
/system identity
set name=MikroTik_servers
problem solved. i added bridge to vlan99 mapping. and deleted additional ipies.
