VLAN: Newbie Needs Guidance
I am new on using mikrotik router, I used 2 WAN on RB2011UiAS-2HnD
I have 3 AP’s and assigned vlan id: 10, 20, 30 on each one, every user on vlan has it’s own different brand of routers.
I apply what i have read on https://wiki.mikrotik.com/wiki/Manual:Switch_Router and
also used Tomas Kirnak Script (https://mum.mikrotik.com/presentations/US12/tomas.pdf) but MODIFIED to attain
Policy Routing. Everything seems working fine but later on i got complains from end user.
Frequent disconnection on Youtube, Netflix and slow Facebook. I Need Help.
# sep/07/2019 22:40:08 by RouterOS 6.45.3
# model = 2011UiAS-2HnD
add name=BridgeOMNI
add name=BridgeVLAN
set [ find default-name=ether2 ] comment=ether2 name=ISP1
set [ find default-name=ether6 ] comment=ether6 name=ISP2
set [ find default-name=ether1 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface vlan
add interface=BridgeVLAN name=VLAN10 vlan-id=10
add interface=BridgeVLAN name=VLAN20 vlan-id=20
add interface=BridgeOMNI name=VLAN30 vlan-id=30
set 3 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 7 default-vlan-id=30 vlan-header=always-strip vlan-mode=secure
set 11 vlan-mode=secure
set 12 vlan-mode=secure
add name=VPOOL10 ranges=192.168.10.100-192.168.10.250
add name=VPOOL20 ranges=192.168.20.100-192.168.20.250
add name=VPOOL30 ranges=192.168.30.100-192.168.30.250
add address-pool=VPOOL10 disabled=no interface=VLAN10 name=DHCP10
add address-pool=VPOOL20 disabled=no interface=VLAN20 name=DHCP20
add address-pool=VPOOL30 disabled=no interface=VLAN30 name=DHCP30
add bridge=BridgeOMNI interface=ether7
add bridge=BridgeVLAN interface=ether3
add bridge=BridgeVLAN interface=ether4
add independent-learning=yes ports=ether3,switch1-cpu switch=switch1 vlan-id=\
    10
add independent-learning=yes ports=ether4,switch1-cpu switch=switch1 vlan-id=\
    20
add ports=ether7,switch2-cpu switch=switch2 vlan-id=30
add address=192.168.10.1/24 interface=VLAN10 network=192.168.10.0
add address=192.168.20.1/24 interface=VLAN20 network=192.168.20.0
add address=192.168.1.220/24 interface=ISP1 network=192.168.1.0
add address=192.168.30.1/24 interface=VLAN30 network=192.168.30.0
add address=192.168.0.220/24 interface=ISP2 network=192.168.0.0
add address=192.168.10.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.20.1
add address=192.168.30.0/24 dns-server=8.8.8.8 gateway=192.168.30.1
/ip firewall address-list
add address=192.168.1.0/24 list=CONNECTED1
add address=192.168.10.0/24 list=CONNECTED1
add address=192.168.20.0/24 list=CONNECTED1
add address=192.168.10.0/24 list=LANLIST1
add address=192.168.20.0/24 list=LANLIST1
add address=192.168.0.0/24 list=CONNECTED2
add address=192.168.30.0/24 list=CONNECTED2
add address=192.168.40.0/24 list=CONNECTED2
add address=192.168.30.0/24 list=LANLIST2
add address=192.168.40.0/24 list=LANLIST2
/ip firewall mangle
add action=accept chain=prerouting dst-address-list=CONNECTED1 \
    src-address-list=CONNECTED1
add action=accept chain=prerouting dst-address-list=CONNECTED2 \
    src-address-list=CONNECTED2
add action=mark-connection chain=input comment="WAN to ROS" connection-mark=\
    no-mark in-interface=ISP1 new-connection-mark=WAN1toROS passthrough=yes
add action=mark-connection chain=input connection-mark=no-mark in-interface=\
    ISP2 new-connection-mark=WAN2toROS
add action=mark-routing chain=output connection-mark=WAN1toROS \
    new-routing-mark=ISP1route
add action=mark-routing chain=output connection-mark=WAN2toROS \
    new-routing-mark=ISP2route
add action=mark-connection chain=forward comment="WAN to LAN" \
    connection-mark=no-mark in-interface=ISP1 new-connection-mark=WAN1toLAN1 \
    passthrough=yes
add action=mark-connection chain=forward connection-mark=no-mark \
    in-interface=ISP2 new-connection-mark=WAN2toLAN2
add action=mark-routing chain=prerouting connection-mark=WAN1toLAN1 \
    new-routing-mark=ISP1route src-address-list=LANLIST1
add action=mark-routing chain=prerouting connection-mark=WAN2toLAN2 \
    new-routing-mark=ISP2route src-address-list=LANLIST2
add action=mark-connection chain=prerouting comment="LAN to WAN" \
    connection-mark=no-mark dst-address-list=!CONNECTED1 dst-address-type=\
    !local new-connection-mark=LAN1toWAN1 passthrough=yes src-address-list=\
    LANLIST1
add action=mark-connection chain=prerouting connection-mark=no-mark \
    dst-address-list=!CONNECTED2 dst-address-type=!local new-connection-mark=\
    LAN2toWAN2 src-address-list=LANLIST2
add action=mark-routing chain=prerouting comment="Load Balancing here" \
    connection-mark=LAN1toWAN1 new-routing-mark=ISP1route passthrough=yes \
add action=mark-routing chain=prerouting connection-mark=LAN2toWAN2 \
    new-routing-mark=ISP2route passthrough=yes src-address-list=LANLIST2
add action=mark-connection chain=prerouting comment=\
    "STICKY CONNECTION after this..." connection-mark=LAN1toWAN1 \
    new-connection-mark=Sticky_ISP1 passthrough=yes routing-mark=ISP1route
add action=mark-connection chain=prerouting connection-mark=LAN2toWAN2 \
    new-connection-mark=Sticky_ISP2 routing-mark=ISP2route
add action=mark-routing chain=prerouting connection-mark=Sticky_ISP1 \
add action=mark-routing chain=prerouting connection-mark=Sticky_ISP2 \
add action=masquerade chain=srcnat out-interface=ISP1
add action=masquerade chain=srcnat out-interface=ISP2
add distance=1 gateway=192.168.1.1 routing-mark=ISP1route
add distance=1 gateway=192.168.0.1 routing-mark=ISP2route
/lcd interface pages
set 0 interfaces=\
    sfp1,ether1,ISP1,ether3,ether4,ether5,ISP2,ether7,ether8,ether9,ether10
So a couple of questions;
  1. Have you looked at the CPU load on the router? When it under full load, what is it getting to?
  2. What speed are your two internet connections?
  3. Are there performance issues with other sites as well or just these sites?
  4. Have you tried the Mangle rule to identify Facebook traffic? L7 filter I use is: add name=Facebook regexp=“^..+\.(facebook.com|facebook.net|fbcdn.com|fbsbx.co
    m|fbcdn.net|fb.com|tfbnw.net).*$”
With thanks
Logical Solutions NZ
  1. I used Hardware Offloading benefits of RB2011UiAS-2HnD so my average cpu usage is 20% and peak 40% on full load.
  2. I have 100Mb connection through FFTH. On Peak hours i still get more than 40Mbps
  3. Same issue on Iflix and Netflix or Youtube slow page refresh on Facebook.
  4. I don’t tend to use Layer7 protocol this time to lessen CPU usage cause i don’t need to filter facebook.
Thank for the reply.
Just one thing I have noticed, be careful with !local and VLANS. I have seen ROS get this wrong a couple of times. I have found a list of private IP’s works better. Also have you tried fast track?
Using mangle rules excludes fast track.
can you enlighten me a bit more about:
Where do i place the fast track? I thought fast track would bypass the mangle rules which i have created.
On my mangle rule, is used to separate each WAN.
ISP1 for VLAN10 and VLAN20 on switch chip 1
ISP2 for VLAN30 on switch chip 2.
Which customers are having problems, all of them (regardless VLAN) or only some?
all of them are experiencing same problem. sad to say including me cause i’m on vlan10
upon looking to my logs, i frequently get dhcp assign and deassign.
I follow some advise to run debug but still don’t have any idea on what’s happening.
sep/09 06:15:36 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:15:36 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:36 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:36 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:15:36 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:47 dhcp,debug,packet DHCP10 received discover with id 540052213 from 0.0.0.0
sep/09 06:15:47 dhcp,debug,packet     flags = broadcast
sep/09 06:15:47 dhcp,debug,packet     ciaddr = 0.0.0.0
sep/09 06:15:47 dhcp,debug,packet     chaddr = 00:30:4F:AB:2F:3B
sep/09 06:15:47 dhcp,debug,packet     Msg-Type = discover
sep/09 06:15:47 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:15:47 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-2F-3B
sep/09 06:15:47 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:15:47 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:15:47 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:15:47 dhcp,info DHCP10 deassigned 192.168.10.233 from 00:30:4F:AB:2F:3B
sep/09 06:15:47 dhcp,debug,packet DHCP10 sending offer with id 540052213 to 255.255.255.255
sep/09 06:15:47 dhcp,debug,packet     yiaddr = 192.168.10.233
sep/09 06:15:47 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:15:47 dhcp,debug,packet     Msg-Type = offer
sep/09 06:15:47 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:15:47 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:47 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:47 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:15:47 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:47 dhcp,debug,packet DHCP10 received request with id 540052213 from 0.0.0.0
sep/09 06:15:47 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:47 dhcp,debug,packet     Address-Request = 192.168.10.233
sep/09 06:15:47 dhcp,info DHCP10 assigned 192.168.10.233 to 00:30:4F:AB:2F:3B
sep/09 06:15:47 dhcp,debug,packet DHCP10 sending ack with id 540052213 to 255.255.255.255
sep/09 06:15:47 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:48 dhcp,debug,packet DHCP30 received request with id 3247872048 from 192.168.30.243
sep/09 06:15:48 dhcp,debug,packet     ciaddr = 192.168.30.243
sep/09 06:15:48 dhcp,debug,packet     chaddr = C8:3A:35:3C:98:30
sep/09 06:15:48 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:48 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:15:48 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-98-30
sep/09 06:15:48 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:15:48 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:15:48 dhcp,debug,packet DHCP30 sending ack with id 3247872048 to 192.168.30.243
sep/09 06:15:48 dhcp,debug,packet     yiaddr = 192.168.30.243
sep/09 06:15:48 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:15:48 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:48 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:15:48 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:48 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:48 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:15:48 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:49 dhcp,debug,packet DHCP30 received request with id 3446472672 from 192.168.30.232
sep/09 06:15:49 dhcp,debug,packet     ciaddr = 192.168.30.232
sep/09 06:15:49 dhcp,debug,packet     chaddr = C8:3A:35:3C:A3:E0
sep/09 06:15:49 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:49 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:15:49 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-A3-E0
sep/09 06:15:49 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:15:49 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:15:49 dhcp,debug,packet DHCP30 sending ack with id 3446472672 to 192.168.30.232
sep/09 06:15:49 dhcp,debug,packet     yiaddr = 192.168.30.232
sep/09 06:15:49 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:15:49 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:49 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:15:49 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:49 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:49 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:15:49 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:49 dhcp,debug,packet DHCP30 received request with id 2879350567 from 192.168.30.218
sep/09 06:15:49 dhcp,debug,packet     ciaddr = 192.168.30.218
sep/09 06:15:49 dhcp,debug,packet     chaddr = E0:13:B5:12:67:27
sep/09 06:15:49 dhcp,debug,packet     Client-Id = 01-E0-13-B5-12-67-27
sep/09 06:15:49 dhcp,debug,packet DHCP30 sending ack with id 2879350567 to 192.168.30.218
sep/09 06:15:49 dhcp,debug,packet     yiaddr = 192.168.30.218
sep/09 06:15:50 dhcp,debug,packet DHCP30 received request with id 4210950088 from 192.168.30.247
sep/09 06:15:50 dhcp,debug,packet     ciaddr = 192.168.30.247
sep/09 06:15:50 dhcp,debug,packet     chaddr = C8:3A:35:3C:8E:C8
sep/09 06:15:50 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:50 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:15:50 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-8E-C8
sep/09 06:15:50 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:15:50 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:15:50 dhcp,debug,packet DHCP30 sending ack with id 4210950088 to 192.168.30.247
sep/09 06:15:50 dhcp,debug,packet     yiaddr = 192.168.30.247
sep/09 06:15:50 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:15:50 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:50 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:15:50 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:50 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:50 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:15:50 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:50 dhcp,debug,packet DHCP30 received request with id 817656944 from 192.168.30.236
sep/09 06:15:50 dhcp,debug,packet     ciaddr = 192.168.30.236
sep/09 06:15:50 dhcp,debug,packet     chaddr = C8:3A:35:3C:74:70
sep/09 06:15:50 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-74-70
sep/09 06:15:50 dhcp,debug,packet DHCP30 sending ack with id 817656944 to 192.168.30.236
sep/09 06:15:50 dhcp,debug,packet     yiaddr = 192.168.30.236
sep/09 06:15:50 dhcp,debug,packet DHCP30 received request with id 4227661732 from 192.168.30.193
sep/09 06:15:50 dhcp,debug,packet     ciaddr = 192.168.30.193
sep/09 06:15:50 dhcp,debug,packet     chaddr = B4:4B:D2:7D:6A:A4
sep/09 06:15:50 dhcp,debug,packet     Client-Id = 01-B4-4B-D2-7D-6A-A4
sep/09 06:15:50 dhcp,debug,packet DHCP30 sending ack with id 4227661732 to 192.168.30.193
sep/09 06:15:50 dhcp,debug,packet     yiaddr = 192.168.30.193
sep/09 06:15:50 dhcp,debug,packet DHCP30 received request with id 4051566496 from 192.168.30.201
sep/09 06:15:50 dhcp,debug,packet     ciaddr = 192.168.30.201
sep/09 06:15:50 dhcp,debug,packet     chaddr = C8:3A:35:3C:A1:A0
sep/09 06:15:50 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-A1-A0
sep/09 06:15:50 dhcp,debug,packet DHCP30 sending ack with id 4051566496 to 192.168.30.201
sep/09 06:15:50 dhcp,debug,packet     yiaddr = 192.168.30.201
sep/09 06:15:51 dhcp,debug,packet DHCP30 received request with id 4203154697 from 192.168.30.235
sep/09 06:15:51 dhcp,debug,packet     ciaddr = 192.168.30.235
sep/09 06:15:51 dhcp,debug,packet     chaddr = B0:6E:BF:84:0D:09
sep/09 06:15:51 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:51 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:15:51 dhcp,debug,packet     Client-Id = 01-B0-6E-BF-84-0D-09
sep/09 06:15:51 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:15:51 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:15:51 dhcp,debug,packet DHCP30 sending ack with id 4203154697 to 192.168.30.235
sep/09 06:15:51 dhcp,debug,packet     yiaddr = 192.168.30.235
sep/09 06:15:51 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:15:51 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:51 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:15:51 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:51 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:51 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:15:51 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:52 dhcp,debug,packet DHCP30 received request with id 1155350838 from 192.168.30.189
sep/09 06:15:52 dhcp,debug,packet     ciaddr = 192.168.30.189
sep/09 06:15:52 dhcp,debug,packet     chaddr = 00:1F:FB:AB:BC:EA
sep/09 06:15:52 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:52 dhcp,debug,packet     Client-Id = 01-00-1F-FB-AB-BC-EA
sep/09 06:15:52 dhcp,debug,packet     Class-Id = "voip"
sep/09 06:15:52 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Host-Name,Domain-Name,Broadcast-Address,Unknown(40),Unknown(41),NTP-Server,Domain-Search
sep/09 06:15:52 dhcp,debug,packet DHCP30 sending ack with id 1155350838 to 192.168.30.189
sep/09 06:15:52 dhcp,debug,packet     yiaddr = 192.168.30.189
sep/09 06:15:52 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:15:52 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:52 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:15:52 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:52 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:52 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:15:52 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:52 dhcp,debug,packet     NTP-Server = 96.44.154.34,63.240.161.99
sep/09 06:15:52 dhcp,debug,packet DHCP30 received request with id 4219273104 from 192.168.30.244
sep/09 06:15:52 dhcp,debug,packet     ciaddr = 192.168.30.244
sep/09 06:15:52 dhcp,debug,packet     chaddr = C8:3A:35:3C:72:90
sep/09 06:15:52 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:15:52 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-72-90
sep/09 06:15:52 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:15:52 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:15:52 dhcp,debug,packet DHCP30 sending ack with id 4219273104 to 192.168.30.244
sep/09 06:15:52 dhcp,debug,packet     yiaddr = 192.168.30.244
sep/09 06:15:52 dhcp,debug,packet DHCP10 received request with id 462548863 from 192.168.10.245
sep/09 06:15:52 dhcp,debug,packet     flags = broadcast
sep/09 06:15:52 dhcp,debug,packet     ciaddr = 192.168.10.245
sep/09 06:15:52 dhcp,debug,packet     chaddr = 68:FF:7B:5B:7F:55
sep/09 06:15:52 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:15:52 dhcp,debug,packet     Client-Id = 01-68-FF-7B-5B-7F-55
sep/09 06:15:52 dhcp,debug,packet     Host-Name = "TL-WR840N"
sep/09 06:15:52 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:15:52 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:15:53 dhcp,debug,packet DHCP10 sending ack with id 462548863 to 255.255.255.255
sep/09 06:15:53 dhcp,debug,packet     flags = broadcast
sep/09 06:15:53 dhcp,debug,packet     ciaddr = 192.168.10.245
sep/09 06:15:53 dhcp,debug,packet     yiaddr = 192.168.10.245
sep/09 06:15:53 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:15:53 dhcp,debug,packet     chaddr = 68:FF:7B:5B:7F:55
sep/09 06:15:53 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:53 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:15:53 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:53 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:53 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:15:53 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:54 dhcp,debug,packet DHCP30 received request with id 4168653112 from 192.168.30.221
sep/09 06:15:54 dhcp,debug,packet     ciaddr = 192.168.30.221
sep/09 06:15:54 dhcp,debug,packet     chaddr = C8:3A:35:3C:99:38
sep/09 06:15:54 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:54 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:15:54 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-99-38
sep/09 06:15:54 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:15:54 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:15:54 dhcp,debug,packet DHCP30 sending ack with id 4168653112 to 192.168.30.221
sep/09 06:15:54 dhcp,debug,packet     yiaddr = 192.168.30.221
sep/09 06:15:54 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:15:54 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:54 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:15:54 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:54 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:54 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:15:54 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:57 dhcp,debug,packet DHCP30 received request with id 4210984216 from 192.168.30.223
sep/09 06:15:57 dhcp,debug,packet     ciaddr = 192.168.30.223
sep/09 06:15:57 dhcp,debug,packet     chaddr = C8:3A:35:3C:85:18
sep/09 06:15:57 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:57 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:15:57 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-85-18
sep/09 06:15:57 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:15:57 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:15:57 dhcp,debug,packet DHCP30 sending ack with id 4210984216 to 192.168.30.223
sep/09 06:15:57 dhcp,debug,packet     yiaddr = 192.168.30.223
sep/09 06:15:57 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:15:57 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:57 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:15:57 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:57 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:57 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:15:57 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:57 dhcp,debug,packet DHCP30 received request with id 633164946 from 192.168.30.197
sep/09 06:15:57 dhcp,debug,packet     flags = broadcast
sep/09 06:15:57 dhcp,debug,packet     ciaddr = 192.168.30.197
sep/09 06:15:57 dhcp,debug,packet     chaddr = 94:0C:6D:AB:D8:8B
sep/09 06:15:57 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:15:57 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Domain-Server,Static-Route,Classless-Route
sep/09 06:15:57 dhcp,debug,packet     Host-Name = "TL-WR541G/542G"
sep/09 06:15:57 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-39-38-00-5F
sep/09 06:15:57 dhcp,debug,packet     Client-Id = 01-94-0C-6D-AB-D8-8B
sep/09 06:15:57 dhcp,debug,packet DHCP30 sending ack with id 633164946 to 255.255.255.255
sep/09 06:15:57 dhcp,debug,packet     yiaddr = 192.168.30.197
sep/09 06:15:57 dhcp,debug,packet DHCP30 received request with id 1236542537 from 192.168.30.198
sep/09 06:15:57 dhcp,debug,packet     ciaddr = 192.168.30.198
sep/09 06:15:57 dhcp,debug,packet     chaddr = 8C:16:45:35:24:49
sep/09 06:15:57 dhcp,debug,packet     Client-Id = 01-8C-16-45-35-24-49
sep/09 06:15:57 dhcp,debug,packet DHCP30 sending ack with id 1236542537 to 192.168.30.198
sep/09 06:15:57 dhcp,debug,packet     yiaddr = 192.168.30.198
sep/09 06:15:58 dhcp,debug,packet DHCP30 received request with id 4202627048 from 192.168.30.240
sep/09 06:15:58 dhcp,debug,packet     ciaddr = 192.168.30.240
sep/09 06:15:58 dhcp,debug,packet     chaddr = C8:3A:35:3C:78:E8
sep/09 06:15:58 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:58 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:15:58 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-78-E8
sep/09 06:15:58 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:15:58 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:15:58 dhcp,debug,packet DHCP30 sending ack with id 4202627048 to 192.168.30.240
sep/09 06:15:58 dhcp,debug,packet     yiaddr = 192.168.30.240
sep/09 06:15:58 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:15:58 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:58 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:15:58 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:58 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:58 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:15:58 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:15:59 dhcp,debug,packet DHCP30 received request with id 1566425659 from 192.168.30.199
sep/09 06:15:59 dhcp,debug,packet     flags = broadcast
sep/09 06:15:59 dhcp,debug,packet     ciaddr = 192.168.30.199
sep/09 06:15:59 dhcp,debug,packet     chaddr = 84:16:F9:3D:3A:23
sep/09 06:15:59 dhcp,debug,packet     Msg-Type = request
sep/09 06:15:59 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:15:59 dhcp,debug,packet     Client-Id = 01-84-16-F9-3D-3A-23
sep/09 06:15:59 dhcp,debug,packet     Host-Name = "TL-WR840N"
sep/09 06:15:59 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:15:59 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:15:59 dhcp,debug,packet DHCP30 sending ack with id 1566425659 to 255.255.255.255
sep/09 06:15:59 dhcp,debug,packet     yiaddr = 192.168.30.199
sep/09 06:15:59 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:15:59 dhcp,debug,packet     Msg-Type = ack
sep/09 06:15:59 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:15:59 dhcp,debug,packet     Address-Time = 600
sep/09 06:15:59 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:15:59 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:15:59 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:00 dhcp,debug,packet DHCP10 received discover with id 1516084833 from 0.0.0.0
sep/09 06:16:00 dhcp,debug,packet     flags = broadcast
sep/09 06:16:00 dhcp,debug,packet     ciaddr = 0.0.0.0
sep/09 06:16:00 dhcp,debug,packet     chaddr = 00:30:4F:AB:2F:3B
sep/09 06:16:00 dhcp,debug,packet     Msg-Type = discover
sep/09 06:16:00 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:00 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-2F-3B
sep/09 06:16:00 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:16:00 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:00 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:00 dhcp,info DHCP10 deassigned 192.168.10.233 from 00:30:4F:AB:2F:3B
sep/09 06:16:00 dhcp,debug,packet DHCP10 sending offer with id 1516084833 to 255.255.255.255
sep/09 06:16:00 dhcp,debug,packet     yiaddr = 192.168.10.233
sep/09 06:16:00 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:00 dhcp,debug,packet     Msg-Type = offer
sep/09 06:16:00 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:00 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:00 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:00 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:00 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:00 dhcp,debug,packet DHCP10 received request with id 1516084833 from 0.0.0.0
sep/09 06:16:00 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:00 dhcp,debug,packet     Address-Request = 192.168.10.233
sep/09 06:16:00 dhcp,info DHCP10 assigned 192.168.10.233 to 00:30:4F:AB:2F:3B
sep/09 06:16:00 dhcp,debug,packet DHCP10 sending ack with id 1516084833 to 255.255.255.255
sep/09 06:16:00 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:02 dhcp,debug,packet DHCP10 received request with id 534878656 from 192.168.10.247
sep/09 06:16:02 dhcp,debug,packet     flags = broadcast
sep/09 06:16:02 dhcp,debug,packet     ciaddr = 192.168.10.247
sep/09 06:16:02 dhcp,debug,packet     chaddr = 00:30:4F:AB:26:41
sep/09 06:16:02 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:02 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:02 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-26-41
sep/09 06:16:02 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:16:02 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:02 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:02 dhcp,debug,packet DHCP10 sending ack with id 534878656 to 255.255.255.255
sep/09 06:16:02 dhcp,debug,packet     yiaddr = 192.168.10.247
sep/09 06:16:02 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:02 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:02 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:02 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:02 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:02 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:02 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:06 dhcp,debug,packet DHCP30 received request with id 4219382305 from 192.168.30.237
sep/09 06:16:06 dhcp,debug,packet     ciaddr = 192.168.30.237
sep/09 06:16:06 dhcp,debug,packet     chaddr = 00:E0:B6:06:AA:21
sep/09 06:16:06 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:06 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:16:06 dhcp,debug,packet     Client-Id = 01-00-E0-B6-06-AA-21
sep/09 06:16:06 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:16:06 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:16:06 dhcp,debug,packet DHCP30 sending ack with id 4219382305 to 192.168.30.237
sep/09 06:16:06 dhcp,debug,packet     yiaddr = 192.168.30.237
sep/09 06:16:06 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:06 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:06 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:06 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:06 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:06 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:06 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:07 dhcp,debug,packet DHCP30 received request with id 49690911 from 192.168.30.187
sep/09 06:16:07 dhcp,debug,packet     flags = broadcast
sep/09 06:16:07 dhcp,debug,packet     ciaddr = 192.168.30.187
sep/09 06:16:07 dhcp,debug,packet     chaddr = 00:30:4F:AB:2F:DB
sep/09 06:16:07 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:07 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:07 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-2F-DB
sep/09 06:16:07 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:16:07 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:07 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:07 dhcp,debug,packet DHCP30 sending ack with id 49690911 to 255.255.255.255
sep/09 06:16:07 dhcp,debug,packet     yiaddr = 192.168.30.187
sep/09 06:16:07 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:07 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:07 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:07 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:07 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:07 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:07 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:09 dhcp,debug,packet DHCP10 received request with id 1226811 from 192.168.10.236
sep/09 06:16:09 dhcp,debug,packet     ciaddr = 192.168.10.236
sep/09 06:16:09 dhcp,debug,packet     chaddr = 00:1B:11:D9:84:C9
sep/09 06:16:09 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:09 dhcp,debug,packet     Client-Id = 01-00-1B-11-D9-84-C9
sep/09 06:16:09 dhcp,debug,packet     Host-Name = "TM-G5240"
sep/09 06:16:09 dhcp,debug,packet     Class-Id = "udhcp 0.9.9-pre"
sep/09 06:16:09 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Host-Name,Domain-Name,Broadcast-Address
sep/09 06:16:09 dhcp,debug,packet DHCP10 sending ack with id 1226811 to 192.168.10.236
sep/09 06:16:09 dhcp,debug,packet     yiaddr = 192.168.10.236
sep/09 06:16:09 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:09 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:09 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:09 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:09 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:09 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:09 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:09 dhcp,debug,packet DHCP10 received request with id 4194238384 from 192.168.10.239
sep/09 06:16:09 dhcp,debug,packet     flags = broadcast
sep/09 06:16:09 dhcp,debug,packet     ciaddr = 192.168.10.239
sep/09 06:16:09 dhcp,debug,packet     chaddr = C8:3A:35:3C:9D:B0
sep/09 06:16:09 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:16:09 dhcp,debug,packet     Client-Id = 01-C8-3A-35-3C-9D-B0
sep/09 06:16:09 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:16:09 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:16:09 dhcp,debug,packet DHCP10 sending ack with id 4194238384 to 255.255.255.255
sep/09 06:16:09 dhcp,debug,packet     yiaddr = 192.168.10.239
sep/09 06:16:11 dhcp,debug,packet DHCP10 received request with id 3606380498 from 192.168.10.242
sep/09 06:16:11 dhcp,debug,packet     ciaddr = 192.168.10.242
sep/09 06:16:11 dhcp,debug,packet     chaddr = 10:BF:48:78:30:D2
sep/09 06:16:11 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:11 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:16:11 dhcp,debug,packet     Client-Id = 01-10-BF-48-78-30-D2
sep/09 06:16:11 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:16:11 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:16:11 dhcp,debug,packet DHCP10 sending ack with id 3606380498 to 192.168.10.242
sep/09 06:16:11 dhcp,debug,packet     yiaddr = 192.168.10.242
sep/09 06:16:11 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:11 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:11 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:11 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:11 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:11 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:11 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:11 dhcp,debug,packet DHCP10 received discover with id 350331965 from 0.0.0.0
sep/09 06:16:11 dhcp,debug,packet     flags = broadcast
sep/09 06:16:11 dhcp,debug,packet     ciaddr = 0.0.0.0
sep/09 06:16:11 dhcp,debug,packet     chaddr = 00:30:4F:AB:2F:3B
sep/09 06:16:11 dhcp,debug,packet     Msg-Type = discover
sep/09 06:16:11 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:11 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-2F-3B
sep/09 06:16:11 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:16:11 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:11 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:11 dhcp,info DHCP10 deassigned 192.168.10.233 from 00:30:4F:AB:2F:3B
sep/09 06:16:11 dhcp,debug,packet DHCP10 sending offer with id 350331965 to 255.255.255.255
sep/09 06:16:11 dhcp,debug,packet     yiaddr = 192.168.10.233
sep/09 06:16:11 dhcp,debug,packet     Msg-Type = offer
sep/09 06:16:11 dhcp,debug,packet DHCP10 received request with id 350331965 from 0.0.0.0
sep/09 06:16:11 dhcp,debug,packet     Address-Request = 192.168.10.233
sep/09 06:16:11 dhcp,info DHCP10 assigned 192.168.10.233 to 00:30:4F:AB:2F:3B
sep/09 06:16:11 dhcp,debug,packet DHCP10 sending ack with id 350331965 to 255.255.255.255
sep/09 06:16:15 dhcp,debug,packet DHCP10 received request with id 3425776503 from 192.168.10.246
sep/09 06:16:15 dhcp,debug,packet     flags = broadcast
sep/09 06:16:15 dhcp,debug,packet     ciaddr = 192.168.10.246
sep/09 06:16:15 dhcp,debug,packet     chaddr = D8:0D:17:E6:BD:5F
sep/09 06:16:15 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:15 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:15 dhcp,debug,packet     Client-Id = 01-D8-0D-17-E6-BD-5F
sep/09 06:16:15 dhcp,debug,packet     Host-Name = "TL-WR840N"
sep/09 06:16:15 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:15 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:16:15 dhcp,debug,packet DHCP10 sending ack with id 3425776503 to 255.255.255.255
sep/09 06:16:15 dhcp,debug,packet     yiaddr = 192.168.10.246
sep/09 06:16:15 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:15 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:15 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:15 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:15 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:15 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:15 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:16 dhcp,debug,packet DHCP30 received request with id 743313473 from 192.168.30.230
sep/09 06:16:16 dhcp,debug,packet     flags = broadcast
sep/09 06:16:16 dhcp,debug,packet     ciaddr = 192.168.30.230
sep/09 06:16:16 dhcp,debug,packet     chaddr = 98:DE:D0:EE:08:41
sep/09 06:16:16 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:16 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:16 dhcp,debug,packet     Client-Id = 01-98-DE-D0-EE-08-41
sep/09 06:16:16 dhcp,debug,packet     Host-Name = "AlipioAllan"
sep/09 06:16:16 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:16 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:16 dhcp,debug,packet DHCP30 sending ack with id 743313473 to 255.255.255.255
sep/09 06:16:16 dhcp,debug,packet     yiaddr = 192.168.30.230
sep/09 06:16:16 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:16 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:16 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:16 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:16 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:16 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:16 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:21 dhcp,debug,packet DHCP10 received request with id 2032809355 from 192.168.10.231
sep/09 06:16:21 dhcp,debug,packet     flags = broadcast
sep/09 06:16:21 dhcp,debug,packet     ciaddr = 192.168.10.231
sep/09 06:16:21 dhcp,debug,packet     chaddr = 00:30:4F:AB:32:45
sep/09 06:16:21 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:21 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:21 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-32-45
sep/09 06:16:21 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:16:21 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:21 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:21 dhcp,debug,packet DHCP10 sending ack with id 2032809355 to 255.255.255.255
sep/09 06:16:21 dhcp,debug,packet     yiaddr = 192.168.10.231
sep/09 06:16:21 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:21 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:21 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:21 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:21 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:21 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:21 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:22 dhcp,debug,packet DHCP30 received request with id 4202485064 from 192.168.30.241
sep/09 06:16:22 dhcp,debug,packet     ciaddr = 192.168.30.241
sep/09 06:16:22 dhcp,debug,packet     chaddr = C8:3A:35:CA:D5:48
sep/09 06:16:22 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:22 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-35-2E-30-00
sep/09 06:16:22 dhcp,debug,packet     Client-Id = 01-C8-3A-35-CA-D5-48
sep/09 06:16:22 dhcp,debug,packet     Host-Name = "Tenda"
sep/09 06:16:22 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:16:22 dhcp,debug,packet DHCP30 sending ack with id 4202485064 to 192.168.30.241
sep/09 06:16:22 dhcp,debug,packet     yiaddr = 192.168.30.241
sep/09 06:16:22 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:22 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:22 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:22 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:22 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:22 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:22 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:23 dhcp,debug,packet DHCP30 received request with id 3447376704 from 192.168.30.225
sep/09 06:16:23 dhcp,debug,packet     ciaddr = 192.168.30.225
sep/09 06:16:23 dhcp,debug,packet     chaddr = 14:6B:9C:B5:57:87
sep/09 06:16:23 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:23 dhcp,debug,packet     Client-Id = 01-14-6B-9C-B5-57-87
sep/09 06:16:23 dhcp,debug,packet     Class-Id = "udhcp 1.12.1"
sep/09 06:16:23 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Host-Name,Domain-Name,Broadcast-Address,NTP-Server
sep/09 06:16:23 dhcp,debug,packet DHCP30 sending ack with id 3447376704 to 192.168.30.225
sep/09 06:16:23 dhcp,debug,packet     yiaddr = 192.168.30.225
sep/09 06:16:23 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:23 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:23 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:23 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:23 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:23 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:23 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:23 dhcp,debug,packet     NTP-Server = 96.44.154.34,63.240.161.99
sep/09 06:16:24 dhcp,debug,packet DHCP10 received discover with id 1326641495 from 0.0.0.0
sep/09 06:16:24 dhcp,debug,packet     flags = broadcast
sep/09 06:16:24 dhcp,debug,packet     ciaddr = 0.0.0.0
sep/09 06:16:24 dhcp,debug,packet     chaddr = 00:30:4F:AB:2F:3B
sep/09 06:16:24 dhcp,debug,packet     Msg-Type = discover
sep/09 06:16:24 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:24 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-2F-3B
sep/09 06:16:24 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:16:24 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:24 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:24 dhcp,info DHCP10 deassigned 192.168.10.233 from 00:30:4F:AB:2F:3B
sep/09 06:16:24 dhcp,debug,packet DHCP10 sending offer with id 1326641495 to 255.255.255.255
sep/09 06:16:24 dhcp,debug,packet     yiaddr = 192.168.10.233
sep/09 06:16:24 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:24 dhcp,debug,packet     Msg-Type = offer
sep/09 06:16:24 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:24 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:24 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:24 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:24 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:24 dhcp,debug,packet DHCP10 received request with id 1326641495 from 0.0.0.0
sep/09 06:16:24 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:24 dhcp,debug,packet     Address-Request = 192.168.10.233
sep/09 06:16:24 dhcp,info DHCP10 assigned 192.168.10.233 to 00:30:4F:AB:2F:3B
sep/09 06:16:24 dhcp,debug,packet DHCP10 sending ack with id 1326641495 to 255.255.255.255
sep/09 06:16:24 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:26 dhcp,debug,packet DHCP30 received request with id 3460565061 from 192.168.30.200
sep/09 06:16:26 dhcp,debug,packet     ciaddr = 192.168.30.200
sep/09 06:16:26 dhcp,debug,packet     chaddr = 14:6B:9C:B0:4D:E1
sep/09 06:16:26 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:26 dhcp,debug,packet     Client-Id = 01-14-6B-9C-B0-4D-E1
sep/09 06:16:26 dhcp,debug,packet     Class-Id = "udhcp 1.12.1"
sep/09 06:16:26 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Host-Name,Domain-Name,Broadcast-Address,NTP-Server
sep/09 06:16:26 dhcp,debug,packet DHCP30 sending ack with id 3460565061 to 192.168.30.200
sep/09 06:16:26 dhcp,debug,packet     yiaddr = 192.168.30.200
sep/09 06:16:26 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:26 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:26 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:26 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:26 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:26 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:26 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:26 dhcp,debug,packet     NTP-Server = 96.44.154.34,63.240.161.99
sep/09 06:16:27 dhcp,debug,packet DHCP10 received request with id 4287669648 from 0.0.0.0
sep/09 06:16:27 dhcp,debug,packet     secs = 65535
sep/09 06:16:27 dhcp,debug,packet     ciaddr = 0.0.0.0
sep/09 06:16:27 dhcp,debug,packet     chaddr = 7C:2E:BD:90:68:5D
sep/09 06:16:27 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:27 dhcp,debug,packet     Client-Id = 01-7C-2E-BD-90-68-5D
sep/09 06:16:27 dhcp,debug,packet     Address-Request = 192.168.10.250
sep/09 06:16:27 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:27 dhcp,debug,packet     Max-DHCP-Message-Size = 1500
sep/09 06:16:27 dhcp,debug,packet     Class-Id = "GoogleWifi"
sep/09 06:16:27 dhcp,debug,packet     Unknown(145) = 01
sep/09 06:16:27 dhcp,debug,packet     Parameter-List = Subnet-Mask,Classless-Route,Static-Route,Router,Domain-Server,Host-Name,Domain-Name,Interface-MTU,Broadcast-Address,Address-Time,Server-Id,Renewal-Time,Rebinding-Time,Domain-Search,Auto-Proxy-Config
sep/09 06:16:27 dhcp,debug,packet DHCP10 sending ack with id 4287669648 to 192.168.10.250
sep/09 06:16:27 dhcp,debug,packet     yiaddr = 192.168.10.250
sep/09 06:16:27 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:27 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:27 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:27 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:27 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:27 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:30 dhcp,debug,packet DHCP30 received request with id 1545412075 from 192.168.30.186
sep/09 06:16:30 dhcp,debug,packet     flags = broadcast
sep/09 06:16:30 dhcp,debug,packet     ciaddr = 192.168.30.186
sep/09 06:16:30 dhcp,debug,packet     chaddr = 84:16:F9:3D:3A:21
sep/09 06:16:30 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:30 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:30 dhcp,debug,packet     Client-Id = 01-84-16-F9-3D-3A-21
sep/09 06:16:30 dhcp,debug,packet     Host-Name = "TL-WR840N"
sep/09 06:16:30 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:30 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:30 dhcp,debug,packet DHCP30 sending ack with id 1545412075 to 255.255.255.255
sep/09 06:16:30 dhcp,debug,packet     yiaddr = 192.168.30.186
sep/09 06:16:30 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:30 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:30 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:30 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:30 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:30 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:30 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:31 dhcp,debug,packet DHCP30 received request with id 4082577197 from 192.168.30.246
sep/09 06:16:31 dhcp,debug,packet     ciaddr = 192.168.30.246
sep/09 06:16:31 dhcp,debug,packet     chaddr = 14:6B:9C:B5:55:ED
sep/09 06:16:31 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:31 dhcp,debug,packet     Client-Id = 01-14-6B-9C-B5-55-ED
sep/09 06:16:31 dhcp,debug,packet     Class-Id = "udhcp 1.12.1"
sep/09 06:16:31 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Host-Name,Domain-Name,Broadcast-Address,NTP-Server
sep/09 06:16:31 dhcp,debug,packet DHCP30 sending ack with id 4082577197 to 192.168.30.246
sep/09 06:16:31 dhcp,debug,packet     yiaddr = 192.168.30.246
sep/09 06:16:31 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:31 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:31 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:31 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:31 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:31 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:31 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:31 dhcp,debug,packet     NTP-Server = 96.44.154.34,63.240.161.99
sep/09 06:16:35 dhcp,debug,packet DHCP10 received discover with id 170922917 from 0.0.0.0
sep/09 06:16:35 dhcp,debug,packet     flags = broadcast
sep/09 06:16:35 dhcp,debug,packet     ciaddr = 0.0.0.0
sep/09 06:16:35 dhcp,debug,packet     chaddr = 00:30:4F:AB:2F:3B
sep/09 06:16:35 dhcp,debug,packet     Msg-Type = discover
sep/09 06:16:35 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:35 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-2F-3B
sep/09 06:16:35 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:16:35 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:35 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:35 dhcp,info DHCP10 deassigned 192.168.10.233 from 00:30:4F:AB:2F:3B
sep/09 06:16:35 dhcp,debug,packet DHCP10 sending offer with id 170922917 to 255.255.255.255
sep/09 06:16:35 dhcp,debug,packet     yiaddr = 192.168.10.233
sep/09 06:16:35 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:35 dhcp,debug,packet     Msg-Type = offer
sep/09 06:16:35 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:35 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:35 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:35 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:35 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:35 dhcp,debug,packet DHCP10 received request with id 170922917 from 0.0.0.0
sep/09 06:16:35 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:35 dhcp,debug,packet     Address-Request = 192.168.10.233
sep/09 06:16:35 dhcp,info DHCP10 assigned 192.168.10.233 to 00:30:4F:AB:2F:3B
sep/09 06:16:35 dhcp,debug,packet DHCP10 sending ack with id 170922917 to 255.255.255.255
sep/09 06:16:35 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:47 dhcp,debug,packet DHCP30 received request with id 1423872096 from 192.168.30.185
sep/09 06:16:47 dhcp,debug,packet     flags = broadcast
sep/09 06:16:47 dhcp,debug,packet     ciaddr = 192.168.30.185
sep/09 06:16:47 dhcp,debug,packet     chaddr = 00:30:4F:AB:32:85
sep/09 06:16:47 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:47 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:47 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-32-85
sep/09 06:16:47 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:16:47 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:47 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:47 dhcp,debug,packet DHCP30 sending ack with id 1423872096 to 255.255.255.255
sep/09 06:16:47 dhcp,debug,packet     yiaddr = 192.168.30.185
sep/09 06:16:47 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:47 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:47 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:47 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:47 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:47 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:47 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:47 dhcp,debug,packet DHCP10 received discover with id 1153118278 from 0.0.0.0
sep/09 06:16:47 dhcp,debug,packet     ciaddr = 0.0.0.0
sep/09 06:16:47 dhcp,debug,packet     chaddr = 00:30:4F:AB:2F:3B
sep/09 06:16:47 dhcp,debug,packet     Msg-Type = discover
sep/09 06:16:47 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-2F-3B
sep/09 06:16:47 dhcp,info DHCP10 deassigned 192.168.10.233 from 00:30:4F:AB:2F:3B
sep/09 06:16:47 dhcp,debug,packet DHCP10 sending offer with id 1153118278 to 255.255.255.255
sep/09 06:16:47 dhcp,debug,packet     yiaddr = 192.168.10.233
sep/09 06:16:47 dhcp,debug,packet     siaddr = 192.168.10.1
sep/09 06:16:47 dhcp,debug,packet     Msg-Type = offer
sep/09 06:16:47 dhcp,debug,packet     Server-Id = 192.168.10.1
sep/09 06:16:47 dhcp,debug,packet     Router = 192.168.10.1
sep/09 06:16:47 dhcp,debug,packet DHCP10 received request with id 1153118278 from 0.0.0.0
sep/09 06:16:47 dhcp,debug,packet     Address-Request = 192.168.10.233
sep/09 06:16:47 dhcp,info DHCP10 assigned 192.168.10.233 to 00:30:4F:AB:2F:3B
sep/09 06:16:47 dhcp,debug,packet DHCP10 sending ack with id 1153118278 to 255.255.255.255
sep/09 06:16:51 dhcp,debug,packet DHCP30 received request with id 2144623571 from 192.168.30.190
sep/09 06:16:51 dhcp,debug,packet     flags = broadcast
sep/09 06:16:51 dhcp,debug,packet     ciaddr = 192.168.30.190
sep/09 06:16:51 dhcp,debug,packet     chaddr = F8:D1:11:51:76:09
sep/09 06:16:51 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:51 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:51 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Domain-Server,Static-Route,Classless-Route,MS-Classless-Route
sep/09 06:16:51 dhcp,debug,packet     Host-Name = "WR340G"
sep/09 06:16:51 dhcp,debug,packet     Class-Id = 4D-53-46-54-20-39-38-00-5F
sep/09 06:16:51 dhcp,debug,packet     Client-Id = 01-F8-D1-11-51-76-09
sep/09 06:16:51 dhcp,debug,packet DHCP30 sending ack with id 2144623571 to 255.255.255.255
sep/09 06:16:51 dhcp,debug,packet     yiaddr = 192.168.30.190
sep/09 06:16:51 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:51 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:51 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:51 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:51 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:51 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:51 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
sep/09 06:16:52 dhcp,debug,packet DHCP30 received request with id 1914404049 from 192.168.30.228
sep/09 06:16:52 dhcp,debug,packet     flags = broadcast
sep/09 06:16:52 dhcp,debug,packet     ciaddr = 192.168.30.228
sep/09 06:16:52 dhcp,debug,packet     chaddr = 00:30:4F:AB:39:C3
sep/09 06:16:52 dhcp,debug,packet     Msg-Type = request
sep/09 06:16:52 dhcp,debug,packet     Max-DHCP-Message-Size = 1024
sep/09 06:16:52 dhcp,debug,packet     Client-Id = 01-00-30-4F-AB-39-C3
sep/09 06:16:52 dhcp,debug,packet     Host-Name = "WNRT-627"
sep/09 06:16:52 dhcp,debug,packet     Class-Id = "MSFT 5.0"
sep/09 06:16:52 dhcp,debug,packet     Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Classless-Route,MS-Classless-Route
sep/09 06:16:52 dhcp,debug,packet DHCP30 sending ack with id 1914404049 to 255.255.255.255
sep/09 06:16:52 dhcp,debug,packet     yiaddr = 192.168.30.228
sep/09 06:16:52 dhcp,debug,packet     siaddr = 192.168.30.1
sep/09 06:16:52 dhcp,debug,packet     Msg-Type = ack
sep/09 06:16:52 dhcp,debug,packet     Server-Id = 192.168.30.1
sep/09 06:16:52 dhcp,debug,packet     Address-Time = 600
sep/09 06:16:52 dhcp,debug,packet     Subnet-Mask = 255.255.255.0
sep/09 06:16:52 dhcp,debug,packet     Router = 192.168.30.1
sep/09 06:16:52 dhcp,debug,packet     Domain-Server = 8.8.8.8,8.8.4.4
If you try pushing all traffic out one ISP, do you still have the problem?
Thanks but i already tried last night till now, unfortunately the same result, my youtube still disconnected and slow facebook.
I ping 8.8.8.8 and get 25 to 28ms reply.
Did you disable the mangle rules?
yes i did.
So I guess you are at the point of using the packet sniffer in ROS and see what wire shark is showing.
Thank you, i think i need to learn more about packing sniffing and wire shark for now .
Have a look on YouTube, many good videos. Basically set up your filters, give it a file name and start it. Get your users to create issue and then download file to local. If you save it as a .pcap file and have wireshark installed, click on the file and it will open in wireshark.
Worth the time to learn!
Just another thing, you make mention of 3rd party routers? I take it theses are wireless AP’s?
If so, have you tested by plugging into the router via Ethernet?
This is not a wireless issue is it?
