Need help to get internet on the vlan.
Here is what was done.
Turned on the hEX router.
connected using winbox
Do the quick setup wizard.
working with internet.(Ethernet 1)
Bridge setup by quick setup has the ip 192.168.88.1
update to 6.48.1
Created a vlan with id 10 on the bridge.
Create the vlan address 192.168.100.1
Create dhcp pool for address. 192.168.100.2 to 199
Created dhcp server
Wireless phone can connected to the wireless ap that is connected to the vlan 10.
Can get the correct ip from the dhcp. But no internet. Cannot ping to 8.8.8.8.
Can ping the vlan 10 ip which is 192.168.100.1
What else needs to be done? Firewall? I am really lost.
Just figured out how to get the current config out of the router. Here is the exported config.
I really hope someone can help to see why there is no internet on the vlan10.
# apr/13/2021 01:30:41 by RouterOS 6.48.1
# software id = SN77-4XZZ
# model = RB750Gr3
# serial number = CC230C681EDF
add admin-mac=48:8F:5A:88:53:73 auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=bridge name=vlan10 vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=vlan10 ranges=192.168.100.2-192.168.100.199
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=vlan10 disabled=no interface=vlan10 name=vlan10
192.168.88.0
add address=192.168.100.1/24 interface=vlan10 network=192.168.100.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=drop chain=forward disabled=yes in-interface=vlan10 \
out-interface-list=!WAN
/system clock
set time-zone-name=Asia/Singapore
/tool mac-server
/tool mac-server mac-winbox
Oh man! This is so embaressing. You are completely right. What a bo bo.
I have added the settings in dhcp-server > network and now it is working.
Thank you so much for the advice. It has been really helpful!
VLAN setup is almost non-existent. I suggest you to read through > this excellent tutorial> .
