Im looking to hand out multiple SSIDs from a Unifi AP connected on Ether22 that are on the various VLANS.
If I setup the SSID to tag traffic on vlan 30 and connect. I am handed an IP in the 10.10.30.0/24 range, which is what I expect. The problem, I have no internet.
I dont understand why and was hoping someone could advise as to what is missing.
For context, if I put a port on VLAN via a PVID, it gets internet and works fine Ether 1,2,3,4 are examples of being on another VLAN that im trying to hand out over wifi
add name=PrimaryBridge vlan-filtering=yes
set [ find default-name=ether1 ] comment="CCTV Back"
set [ find default-name=ether2 ] comment="CCTV Front Right"
set [ find default-name=ether3 ] comment="CCTV Front Left"
set [ find default-name=ether9 ] comment=NAS
set [ find default-name=ether10 ] comment=PX3
set [ find default-name=ether11 ] comment=PX2
set [ find default-name=ether12 ] comment=PX1
set [ find default-name=ether22 ] comment=WAP
set [ find default-name=ether24 ] name="ether24 -WAN"
set [ find default-name=sfp-sfpplus2 ] comment="Office Uplink"
set [ find default-name=sfp-sfpplus3 ] comment="Synology NAS"
set [ find default-name=sfp-sfpplus4 ] comment="Synology NAS"
/interface vlan
add interface=PrimaryBridge name=CCTV vlan-id=40
add interface=PrimaryBridge name=Guest vlan-id=30
add interface=PrimaryBridge name=Local vlan-id=20
add interface=PrimaryBridge name=Production vlan-id=10
add name=WAN
add name=LAN
add name=WinboxConnection
add comment=Production name=dhcp_pool1 ranges=10.10.10.20-10.10.10.254
add comment=Guest name=dhcp_pool3 ranges=10.10.30.20-10.10.30.254
add comment=CCTV name=dhcp_pool4 ranges=10.10.40.20-10.10.40.254
add comment=Local name=dhcp_pool2 ranges=10.10.20.20-10.10.20.254
add address-pool=dhcp_pool1 interface=Production name=Production-DHCP
add address-pool=dhcp_pool3 interface=Guest name=Guest-DHCP
add address-pool=dhcp_pool4 interface=CCTV name=CCTV-DHCP
add address-pool=dhcp_pool2 interface=Local name=Local-DHCP
/port
set 0 name=serial0
add bridge=PrimaryBridge interface=ether4 pvid=40
add bridge=PrimaryBridge interface=ether5 pvid=40
add bridge=PrimaryBridge interface=ether6 pvid=10
add bridge=PrimaryBridge interface=ether7 pvid=10
add bridge=PrimaryBridge interface=ether8 pvid=10
add bridge=PrimaryBridge interface=ether9 pvid=10
add bridge=PrimaryBridge interface=ether2 pvid=40
add bridge=PrimaryBridge interface=ether10 pvid=10
add bridge=PrimaryBridge interface=ether11 pvid=10
add bridge=PrimaryBridge interface=ether12 pvid=10
add bridge=PrimaryBridge interface=ether13 pvid=10
add bridge=PrimaryBridge interface=ether14 pvid=10
add bridge=PrimaryBridge interface=ether15 pvid=10
add bridge=PrimaryBridge interface=ether16 pvid=10
add bridge=PrimaryBridge interface=ether17 pvid=10
add bridge=PrimaryBridge interface=ether18 pvid=10
add bridge=PrimaryBridge interface=ether19 pvid=10
add bridge=PrimaryBridge interface=ether20 pvid=10
add bridge=PrimaryBridge interface=sfp-sfpplus1 pvid=10
add bridge=PrimaryBridge interface=sfp-sfpplus2 pvid=10
add bridge=PrimaryBridge interface=sfp-sfpplus3 pvid=10
add bridge=PrimaryBridge interface=sfp-sfpplus4 pvid=10
add bridge=PrimaryBridge interface=ether21 pvid=10
add bridge=PrimaryBridge interface=ether1 pvid=40
add bridge=PrimaryBridge interface=ether22 pvid=10
add bridge=PrimaryBridge interface=ether3 pvid=40
/interface bridge vlan
add bridge=PrimaryBridge tagged=PrimaryBridge,ether22 vlan-ids=10
add bridge=PrimaryBridge tagged=PrimaryBridge,ether22,ether12 vlan-ids=20
add bridge=PrimaryBridge tagged=PrimaryBridge,ether22,ether12 vlan-ids=30
add bridge=PrimaryBridge tagged=PrimaryBridge,ether22,ether12 vlan-ids=40
/interface detect-internet
set detect-interface-list=all
add interface="ether24 -WAN" list=WAN
add interface=Production list=LAN
add interface=ether23 list=LAN
add interface=CCTV list=LAN
add interface=Guest list=LAN
add interface=Local list=LAN
add interface=PrimaryBridge list=LAN
add address=10.10.10.1/24 interface=Production network=10.10.10.0
add address=10.10.20.1/24 interface=Local network=10.10.20.0
add address=10.10.30.1/24 interface=Guest network=10.10.30.0
add address=10.10.40.1/24 interface=CCTV network=10.10.40.0
add address=192.168.0.1 interface=ether23 network=192.168.0.1
/ip cloud
set ddns-enabled=yes update-time=no
/ip dhcp-client
add address=10.10.10.0/24 comment=Production dns-server=10.10.10.2 gateway=\
10.10.10.1
add address=10.10.20.0/24 comment=Local dns-server=10.10.10.2 gateway=\
10.10.20.1
add address=10.10.30.0/24 comment=Guest dns-server=10.10.10.2 gateway=\
10.10.30.1
add address=10.10.40.0/24 comment=CCTV dns-server=10.10.10.2 gateway=10.10.40.1
/ip firewall address-list
add address=0.0.0.0/8 comment=RFC6890 list=no_forward_ipv4
add address=169.254.0.0/16 comment=RFC6890 list=no_forward_ipv4
add address=224.0.0.0/4 comment=" multicast" list=no_forward_ipv4
add address=255.255.255.255 comment=RFC6890 list=no_forward_ipv4
add action=accept chain=forward comment="Allow VLAN 30 to WAN" in-interface=\
Guest out-interface-list=WAN
add action=accept chain=input comment="accept ICMP" protocol=icmp
add action=accept chain=input comment="accept established,related,untracked" \
add action=accept chain=forward disabled=yes in-interface=CCTV out-interface=\
"ether24 -WAN"
add action=accept chain=forward disabled=yes dst-port=554 protocol=tcp
add action=drop chain=input comment="drop all not coming from LAN" \
in-interface-list=!LAN
add action=accept chain=forward comment="accept all that matches IPSec policy" \
ipsec-policy=in,ipsec
add action=fasttrack-connection chain=forward comment=" fasttrack" \
add action=accept chain=forward comment="accept established,related, untracked" \
add action=drop chain=forward comment="drop invalid" connection-state=invalid
add action=drop chain=forward comment="drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment="drop bad forward IPs" src-address-list=\
no_forward_ipv4
add action=drop chain=forward comment="drop bad forward IPs" dst-address-list=\
no_forward_ipv4
add action=masquerade chain=srcnat comment="Hairpin NAT" disabled=yes \
dst-address=10.10.10.0/24 out-interface=PrimaryBridge src-address=\
10.10.10.0/24
add action=masquerade chain=srcnat comment=" masquerade" out-interface-list=WAN
add action=accept chain=srcnat comment=" accept all that matches IPSec policy" \
ipsec-policy=out,ipsec
add action=dst-nat chain=dstnat comment="Satisfactory Game Server" dst-address=\
82.39.60.222 dst-port=7777 in-interface="ether24 -WAN" protocol=tcp \
to-addresses=10.10.10.101 to-ports=7777
82.39.60.222 dst-port=7777 in-interface="ether24 -WAN" protocol=udp \
/ip firewall service-port
set ftp disabled=yes
set h323 disabled=yes
/ip hotspot profile
/ip ipsec profile
/system clock
set time-zone-name=Europe/London
/system identity
set name=StrawberryRouter
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.uk.pool.ntp.org
add address=1.uk.pool.ntp.org
add address=2.uk.pool.ntp.org
add address=3.uk.pool.ntp.org
/system routerboard settings
# Firmware upgraded successfully, please reboot for changes to take effect!
set auto-upgrade=yes
