I have a problem with my VLAN setup where untagged traffic from interface sfp-sfpplus4 does not receive an IP from the DHCP server on VLAN50 ( instead, it’s getting IP from VLAN1), in my understanding, traffic should be tagged by the crs305.
Here’s my setup, there must be something wrong with it but I can’t see it
add name=BR1
add name=WAN
add name=LAN
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=ether1 pvid=50
add bridge=BR1 interface=sfp-sfpplus1
add bridge=BR1 interface=sfp-sfpplus2
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=sfp-sfpplus3 pvid=50
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=sfp-sfpplus4 pvid=50
/interface bridge vlan
add bridge=BR1 tagged=sfp-sfpplus1 untagged=sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,BR1 vlan-ids=50
add bridge=BR1 tagged=sfp-sfpplus1 vlan-ids=100
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=WAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
/ip dhcp-client
add interface=BR1
/ip hotspot profile
/ip service
set telnet disabled=yes
set api disabled=yes
/system identity
set name=Crs305
/system leds
set 0 disabled=yes
set 1 disabled=yes
set 2 disabled=yes
set 3 disabled=yes
/system leds settings
set all-leds-off=immediate
/system note
set show-at-login=no
/system routerboard settings
set boot-os=router-os
While reading my initial post, I realize that I left some things out that could help in the understanding of the setup.
ether1 => not used at the moment but planned to be used for some extra 1G connectivity if needed
sfp-sfpplus1 => will be connected to another switch will tagged traffic, so this port is a trunk
sfp-sfpplus2 => connected to my router which runs a DHCP server per VLAN , also trunk
sfp-sfpplus3 => unused yet but will be like sfp-sfpplus4 if used one day
sfp-sfpplus4 => connected to a server which should get tagged with VLAN 50 and get an IP from DHCP server running on the router ( plugged to sfp-sfpplus2)
The setting for sfp-sfpplus2 (under bridge/port) lacks setting of PVID … and default is PVID=1 … OTOH it’s set as untagged for VLAN 50 … so you have a discrepancy here.
