I can not “ping”/connect my vlan IP what is strange DHCP is workign and assigning IP to clients, but clients can’t connect to my CRS125. Here is my simple config:
[admin@MikroTik] /ip route> /export
# feb/18/2018 21:36:40 by RouterOS 6.41.2
# software id = NPD6-SUAU
# model = CRS125-24G-1S
# serial number = 738006D3BDD1
add name=bridge-IPTV
add name=switch-br0 protocol-mode=none
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether13 ] name=ether13-TV
/interface vlan
add interface=switch-br0 name=vlan10-internal vlan-id=10
add interface=ether1-WAN name=vlan103 vlan-id=103
/interface ethernet switch
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports="ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,\
ether11,ether12,ether14,ether15,ether16,ether17,ether18,ether19,ether20,ether21,ether22,ether23,ether24,sfp1"
add name=dhcp_pool0 ranges=192.168.10.10-192.168.10.254
add address-pool=dhcp_pool0 disabled=no interface=vlan10-internal name=dhcp-vlan10
/interface pppoe-client
add disabled=no interface=ether1-WAN name=pppoe-interbeskidy password=paassswwoord profile=default-encryption use-peer-dns=yes \
user=user1
add bridge=bridge-IPTV interface=ether13-TV
add bridge=bridge-IPTV interface=vlan103
add bridge=switch-br0 interface=ether2
add bridge=switch-br0 interface=ether3
add bridge=switch-br0 interface=ether4
add bridge=switch-br0 interface=ether5
add bridge=switch-br0 interface=ether6
add bridge=switch-br0 interface=ether7
add bridge=switch-br0 interface=ether8
add bridge=switch-br0 interface=ether9
add bridge=switch-br0 interface=ether10
add bridge=switch-br0 interface=ether11
add bridge=switch-br0 interface=ether12
add bridge=switch-br0 interface=ether14
add bridge=switch-br0 interface=ether15
add bridge=switch-br0 interface=ether16
add bridge=switch-br0 interface=ether17
add bridge=switch-br0 interface=ether18
add bridge=switch-br0 interface=ether19
add bridge=switch-br0 interface=ether20
add bridge=switch-br0 interface=ether21
add bridge=switch-br0 interface=ether22
add bridge=switch-br0 interface=ether23
add bridge=switch-br0 interface=ether24
add bridge=switch-br0 interface=sfp1
/interface bridge vlan
add bridge=switch-br0 untagged=ether10 vlan-ids=10
/interface ethernet switch egress-vlan-tag
add tagged-ports=sfp1,switch1-cpu vlan-id=10
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=10 ports="ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12\
add ports="ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether14,ether15,ether16,ether17,et\
her18,ether19,ether20,ether21,ether22,ether23,ether24,sfp1,switch1-cpu" vlan-id=10
add address=192.168.10.1/24 interface=vlan10-internal network=192.168.10.0
add address=192.168.10.0/24 gateway=192.168.10.1
set allow-remote-requests=yes
add action=masquerade chain=srcnat out-interface=pppoe-interbeskidy
add distance=1 gateway=pppoe-interbeskidy pref-src=xxx.xxx.xxx.xxx
/ip service
set telnet disabled=yes
set ssh address=0.0.0.0/0 port=2222
/system clock
set time-zone-name=Europe/Warsaw
Did i miss something?
EDIT:
After upgrade to 6.42rc version even IP is not assigning. Are VLAN/Switch functionalities broken in newest 6.41 and 6.42rc when they ware moved from master ports to bridge? Do anyone experiencing similar problems?
