VLAN not working with switch HP
I connected the ethernet 1 of my RB951ui-2hnd with a switch HP JE009A running a VLAN but is not working. :frowning:
What is I did was:
  1. Add a VLAN to the ethernet 1
  2. Configured the VLAN ID
  3. Configure the IP of the VLAN
  4. Configure the routes
    Everything is very simple but I’m missing something because the link is down (I see the interface with ‘R’ but in the status the link is down).
    Are you familiar with some kind of additional settings I should change to make it work with this switch?
    Thanks!!
Maybe the problem is with the Spanning Tree Protocol (STP)? Anyone familiar with it? I’m not sure if it should be enabled or not for the VLAN (in the HP switch) and what value should I use? something to do about this in the Mikrotik side?
Thanks!!
