VLAN Omnitik + SXT
Hello
I want to create VLAN on SXT which i want to connect with Ominitik 5.8Ghz Can any one suggest me the best option to create VLAN by which we can get best out put of the resources !!!
As i connected 7 client on one Omnitik with NV2 working well but some times the it affect internally, So i want to setup and create more secure network
Please advice
NT
securityprofile and default forward no, and you should be secured.
its possible to mess around with a lot of vland, but for no reasion at all.
connect CPE trough pppoe, have forward no, and security profile, and none of the CPE will se eachoter.
vlan is easy to sniff, and just setup to own hardware. a pppoe username/password, and WPA2 is a lot more secure.
Hello
Some time as client CPE due to any reason i am getting issue of too much flooding and due to flooding all my customers are getting disturb, can any one advice how to create VLAN on dynamic WDS so that one customer network issue wont affect the other one which help me more to run network stable way
NT
