Is there an easy way to create a VLAN on every interface instead of specifying every single interface?
I need to create a couple of VLANs and some of them need to be available on all interfaces. Do I manually have to add ever interface to every VLAN in this case or is there a setting that will allow all interfaces?
Thanks,
-Patric
If you’re doing software based bridging then it’s fairly straightforward. Create a bridge interface and add all the Ethernet interfaces you want as bridge ports. Then create a VLAN interface. Specify the bridge as the interface argument.
interface bridge add name=br1 disabled=no protocol-mode=rstp
interface bridge port add bridge=br1 interface=ether2
interface bridge port add bridge=br1 interface=ether3
interface bridge port add bridge=br1 interface=ether4
interface vlan add name=br1-vlan21 vlan-id=21 interface=br1
interface vlan add name=br1-vlan22 vlan-id=22 interface=br1
This results in VLANs 21 and 22 being tagged out to ether2, 3, and 4.
