VLAN on Bridged Interfaces
Hi there !
Trying as follows:
2 RB750
All Ports added to one bridge !
The 2 RB750 are connected directly, and there is traffic on them (without VLAN)
Now i’d like to configure a trunk between this to RBs forwarding ALL DATA (VLAN + NON VLAN)
I can configure Interfaces, VLAN, IP, etc.
But I am not able to ping one RB from the other one vice versa.
Adding the VLANs to an other bridge and setting up the IP onto the bridge won’t change the situation.
BTW the configuration of my two boxes:
Router 24:
jan/08/1970 05:10:11 by RouterOS 5.4
software id = P6UH-FXX2
add admin-mac=00:00:00:00:00:00 ageing-time=5m arp=enabled auto-mac=yes
disabled=no forward-delay=15s l2mtu=1524 max-message-age=20s mtu=1500
name=bridge_switch priority=0x8000 protocol-mode=none
transmit-hold-count=6
set 0 arp=enabled auto-negotiation=yes disabled=no full-duplex=yes l2mtu=1526
mac-address=00:0C:42:87:0F:97 mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:87:0F:98
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:87:0F:99
master-port=none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:87:0F:9A
master-port=none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:87:0F:9B
master-port=none mtu=1500 name=ether5 speed=100Mbps
/interface vlan
add arp=enabled disabled=no interface=ether1 l2mtu=1522 mtu=1500 name=
vlan_20_P1 use-service-tag=no vlan-id=20
add arp=enabled disabled=no interface=ether5 l2mtu=1520 mtu=1500 name=
vlan_20_P5 use-service-tag=no vlan-id=20
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
set default authentication-types=“” eap-methods=passthrough group-ciphers=“”
group-key-update=5m interim-update=0s management-protection=disabled
management-protection-key=“” mode=none name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“”
static-sta-private-algo=none static-sta-private-key=“”
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers=“” wpa-pre-shared-key=“”
wpa2-pre-shared-key=“”
/ip hotspot profile
set default dns-name=“” hotspot-address=0.0.0.0 html-directory=hotspot
http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap
name=default rate-limit=“” smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=
1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m
name=default pfs-group=modp1024
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=
default use-encryption=default use-mpls=default use-vj-compression=
default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=
default use-compression=default use-encryption=yes use-mpls=default
use-vj-compression=default
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514
sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000
red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=
5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter=“” redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=“”
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=
default
/snmp
set contact=“” enabled=no engine-id=“” location=“” trap-target=0.0.0.0
trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password=“”
authentication-protocol=MD5 encryption-password=“” encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514
src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto target=
remote
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=
400MHz force-backup-booter=no silent-boot=no
/user group
add name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,web,sn
iff,sensitive,api,!ftp,!write,!policy” skin=default
add name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,password
,web,sniff,sensitive,api,!ftp,!policy” skin=default
add name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,winbo
x,password,web,sniff,sensitive,api” skin=default
add bridge=bridge_switch disabled=no edge=auto external-fdb=auto horizon=none
interface=ether1 path-cost=10 point-to-point=auto priority=0x80
interface=ether5 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
set ether2 vlan-header=leave-as-is vlan-mode=fallback
set ether3 vlan-header=leave-as-is vlan-mode=fallback
set ether4 vlan-header=leave-as-is vlan-mode=fallback
set ether5 vlan-header=leave-as-is vlan-mode=fallback
set switch1_cpu vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:C3:20:57:EE:75
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.5.24/24 disabled=no interface=bridge_switch network=
192.168.5.0
add address=10.0.0.24/24 disabled=no interface=vlan_20_P5 network=10.0.0.0
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=512
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set ether4 discover=yes
set ether5 discover=yes
set bridge_switch discover=yes
set vlan_20_P1 discover=no
set vlan_20_P5 discover=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=none max-client-connections=
600 max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0
parent-proxy-port=0 port=8080 serialize-connections=no src-address=
0.0.0.0
add disabled=no distance=1 dst-address=192.168.60.64/26 gateway=192.168.5.21
scope=30 target-scope=10
/ip service
set telnet disabled=no port=23
set ftp disabled=no port=21
set www disabled=no port=80
set ssh disabled=no port=22
set www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set ether4 queue=ethernet-default
set ether5 queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system console
add disabled=no term=vt102
/system health
set
/system identity
set name=OG01
/system logging
add action=memory disabled=no prefix=“” topics=info
add action=memory disabled=no prefix=“” topics=error
add action=memory disabled=no prefix=“” topics=warning
add action=echo disabled=no prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set address=0.0.0.0 from=<> password=“” port=25 user=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
set (unknown) disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number=“” channel=0 keep-max-sms=0 receive-enabled=no secret=“”
/tool sniffer
set file-limit=10 file-name=“” filter-address1=0.0.0.0/0:0-65535
filter-address2=0.0.0.0/0:0-65535 filter-protocol=all-frames
filter-stream=yes memory-limit=10 memory-scroll=yes only-headers=no
streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
Router 25:
jan/03/1970 04:05:29 by RouterOS 5.4
software id = R75B-B4H7
mac-address=00:0C:42:86:CC:58 mtu=1500 name=ether1 speed=100Mbps
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:86:CC:59
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:86:CC:5A
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:86:CC:5B
disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:86:CC:5C
/interface vlan
/ip hotspot profile
use-radius=no
/ip ipsec proposal
/ppp profile
default
/queue type
sfq-perturb=5
5
/routing ospf area
default
/snmp
trap-version=1
/snmp community
remote
/user group
add disabled=no edge=auto external-fdb=auto horizon=none interface=ether2
interface=ether3 path-cost=10 point-to-point=auto priority=0x80
interface=ether4 path-cost=10 point-to-point=auto priority=0x80
add disabled=no edge=auto external-fdb=auto horizon=none path-cost=10
no
default enabled=no keepalive-timeout=60 mac-address=FE:9E:DD:32:1A:77
/ip accounting
add address=192.168.5.25/24 disabled=no interface=bridge_switch network=
192.168.5.0
add address=10.0.0.25/24 disabled=no interface=vlan_20_P5 network=10.0.0.0
/ip proxy
0.0.0.0
/ip service
/ip socks
/ip ssh
/ip traffic-flow
/ip upnp
/mpls
/mpls interface
/mpls ldp
/port firmware
/ppp aaa
/queue interface
/radius incoming
/routing mme
/routing rip
/store
/system clock
/system console
/system health
set
/system identity
set name=EG01
/system logging
/system note
/system ntp client
set 0 cpu=auto
set 1 cpu=auto
0.0.0.0 user=“”
/system watchdog
100
/tool e-mail
/tool graphing
/tool mac-server
set enabled=yes
/tool sms
/tool sniffer
filter-stream=yes interface=vlan_20_P5 memory-limit=10 memory-scroll=yes
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/user aaa
