If you want to use ethernet ports as a group of switched ports, then you have to configure bridge and add relevant ports. And that’s true in all cases. It doesn’t work without it.
The difference between switch-chip way and bridge-way (both software and HW-offloaded) is that for the later one has to set vlan-filtering property of bridge to “yes” and for the former to “no”. And, of course, set the rest of L2 VLAN settings in appropriate place.
passing frames between different ports within same VLAN.
Almist all MT devices, which have switch chips built in, can HW offload this, either automatically (bridge config) or by manual configuration (switch chip config)
interaction of RouterOS with devices in certain VLANs
This includes wireless traffic as well. In this case vast majority of work gets done by CPU and not much can be actually offloaded to switch chip. The difference between offloaded and non-offloaded is negligible.
Not sure what kind of use case you are mentioning in your last post.
Interesting, thanks again for sharing the detailed explanation.
In my personal case I have an RB4011 with couple of VLANs configured as standard bridge-way and an wAP LTE (without wireless active) as second WAN using the second example switch-way without bridge.
