Hello! Please, help me with such configuration as you can see on attachment.
This is simplified config, after that i want to add a vpn server (with separate dhcp address pool) to access internal (192.168.200.0/24) lan.
What i need:
- WAN (Eher1) port should be with Vlanid 20 and with ip 192.168.100.22 (my isp have 1:1 nat to this ip)
- Eher2 port should have 192.168.200.2 ip to access internal network (dhcp server for 192.168.200.128/25 (yes /25) network we have on another router).
I tried to create this config using mikrotik default config adding VLAN to interfaces, but without luck. I stuck on assigning this VLAN to Eher1 interface.
